Old 11-22-2015   #41
tpepmeie
Default Re: Interest in Main Bearing studs
Most of you should have these by now. I realized I should provide some guidance for torque values. Using either oil or ARP ultra torque on the threads and washers, you should tighten to:
M10: 52 ft-lbs (in two steps)
M12: 80 ft-lbs (in three steps)
At those levels, you'll stretch the studs to approximately 75% of the yield strength. You'll want to put several (3-5) torque cycles on the fasteners to burnish the threads and stabilize the friction value.
Note: the fine threads on the nut end of the studs are not the same pitch as the OEM fasteners. You should not use the same torque-angle specification as the stock bolts. That will result in under torqued studs.
If you want to use torque-angle methods, contact me offline and I can provide the angles.
Old 11-22-2015   #42
What exactly is 3-5 torque cycles?
Old 11-22-2015   #43
tpepmeie
Tighten and release. For most builders, this happens anyway as you pre-assemble, hone, measure clearances, and re-assemble. The point is simply to burnish the threads so you get an accurate and consistent stretch using the torque method.
Old 11-22-2015   #44
Tighten them several times...not torque them....which makes sense. Thank you
Old 06-03-2017   #45
tpepmeie
These are available once again-- I recently had another batch made.
17-4ph steel for these latest ones. Same price. $550/set.
2-bolt motors only for now....
Old 06-03-2017   #46
spork2367
Why the switch to 17-4?
Old 06-03-2017   #47
tpepmeie
Exchange rate helped, so it all got a bit cheaper. So I just upgraded the material. No real operational benefit.
Old 06-15-2022   #48
Are these available?
