Old 4 Days Ago   #1
Young1
Young1's Avatar
Default Seat track transmission rebuild kit
I installed the 5 piece C4 seat transmission rebuild kit today. $19.95 from Amazon. Went ok until I discovered the parts would not snap into the aluminum case by 3/32 inch. The 6 blind holes for the shafts were too shallow. I drilled out the plastic till the shafts laid in place. Got it all back together and tested with a drill. I have 4 hours into it. I took it apart to evaluate the brokenness before ordering the kit. BTW on eBay there is a kit for $120.00 with many more pieces if needed. If I can do it others out there can also. Got to get it in the Z to head out to MR11 Sunday morning. I hope it holds up.
Steve Young
Second Owner
SOLD
SOLD
Old 4 Days Ago   #2
secondchance
Default Re: Seat track transmission rebuild kit
Congratulations Steve. Salute your resolve and talent. My driver side was acting up for rear up and down movement. Took the 3 motor module apart and had a heck of a time putting it back together. Since driver side was working partially, switched with passenger side after adjusting the rear height with a drille, and magically got it to work. Strange but too happy to ask how it started to work properly. Reinstalled and all?s been well ever since.
Old 2 Days Ago   #3
Young1
Young1's Avatar
The replacement small gear for front rear movement stripped with my weight in seat. Worked on bench but not in the field. I will install the $120 kit in the future and report on it.
Steve Young
Second Owner
SOLD
SOLD
