Old 06-08-2019   #1
Neat
Default Freon capacity for 91 ZR-1?
I've been all over the web, and for whatever reason I can't seem to get an answer as to how much refrigerant (R12) my 91 ZR-1 will hold. I've checked the various stickers under the hood, none of them show a Freon capacity.
1991 ZR-1 #769 - Turquoise / black - DRM 475 - 12.2 @ 121 -
1993 Mustang - White / Black - 5.3 Chevrolet Engine - Twin Turbos - Other Stuff - 8.62 @ 156 -
Neat is offline   Reply With Quote
Old 06-08-2019   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Freon capacity for 91 ZR-1?
Have you checked your FSM? Pretty sure it's in there.
Mine is a '90, but I'll look in my book when I have a few minutes.
Kenny
1990 #442
Old 06-08-2019   #3
Neat
My FSM is tucked away in the attic with the other top to the car. I need to just go get the ladder and bring the FSM down - it doesn't do any good to anyone up in the rafters.
Old 06-09-2019   #4
Jagdpanzer
Jagdpanzer's Avatar
94 FSM
With R-134
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-09-2019   #5
TX '90 ZR1
TX '90 ZR1's Avatar
Sorry for the delay in getting back.
My '90 FSM shows 2.25 lbs of R-12.
Kenny
1990 #442
Old 07-06-2020   #6
emmvette
emmvette's Avatar
Bringing up an old thread. So for my '90, it is 2.25 pounds of R12. Does that convert straight across for R-134? I'm wondering since the R-134 is less efficient if it needs more or the same amount?
emmvette is offline   Reply With Quote
Old 07-06-2020   #7
Subfixer
Subfixer's Avatar
Only 2lbs for R-134a.
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 07-07-2020   #8
No.. R12 at 2.25 will be around 1.8lbs (at the high end) of R-134a
Typically R-134a is about 75-80% of the R12 fill.
reason the later cars are at 2lbs vs 2.25 is the added capacity of the parallel flow condenser vs the tube and fin condenser
Old 05-18-2024   #9
jrd1990zr1
jrd1990zr1's Avatar
Jeff,
Sorry I know this is an old thread.
So if one is converting their 1990 ZR1 to R134a the charge should be between 27 oz. and 28.8 oz., correct?
Do you know what the proper high side and low side pressures should be?
Thank you.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 05-18-2024   #10
Yes that is correct..
