![]() Join Date: Apr 2015
When the key is turned to electrics on, but prior to start, this clicks quite audibly ever 1.5 seconds. What is it, and is it supposed to make that sound? It's located under the hood up towards the right front facia of the '94 Z.
(BTW, Z manuals are on order!) ![]()
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
Secondary vacuum pump. If its turning on every few seconds, you have a vacuum leak somewhere in the system.
![]() Join Date: Apr 2004
Sounds like it is trying to cycle on once on it should run at least a few seconds. It is the vacuum pump for the secondary's. It may be repairable. Check out Dynomite's sticky's or I'm sure he will post up a link.
#5 | |
The Z starts right up, idles great, runs smooth and like a beast. Appears to be all stock, 19k miles. Wasn't driven but 1,700 miles in the last 9 years. Narrow it down any? ![]()
#6 | |
Checking for Vacuum Leaks TIPS Finding Vacuum Leak TIPS 1. Secondary Vacuum System The first photo shows details of the vacuum plumbing around the Secondary Vacuum Solenoid and Secondary Vacuum Reservoir Including the Check Valve. The second photo is the complete Secondary Vacuum System. The Check Valve allows plenum vacuum to be seen by Secondary Vacuum Reservoir but does not allow plenum to see Vacuum pump vacuum. ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-17-2015 at 08:59 PM. |
#7 | |
The rubber fitting appeared to be very lose, and I zip-tied it to hold the nylon vacuum line tighter, but no change in the 1.5s cycling of the vacuum pump. Must be the aforementioned leaky check valve? Great pics, BTW!
#8 | |
Vacuum Check Valve Make sure it is installed correct direction ![]() Unfortunately you have to remove Plenum to Replace Check Valve.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#9 | |
Well, in the meantime… 1. Is there any problem with driving it for a bit before I do this? 2. What does that vacuum pump do for the secondaries before start? 3. Trying to keep it stock… for a least a month or two or three… and drive and enjoy it. But, what else should one check or replace when finally pulling the Plenum? Thanks for the tremendous help! G
#10 |
just replace every part you can.
