Old 07-20-2014   #1
larry.schenk
Default no spark on 5 & 8
Replaced all coil packs because I had a no spark condition on 5 & 8, after replacing I still have the same issues. Anyone seen anything like this? Car started missing then smoke was coming from back of engine, smelling electrical...
larry.schenk is offline   Reply With Quote
Old 07-21-2014   #2
Z06scentair
Z06scentair's Avatar
Default Re: no spark on 5 & 8
DIS Module.....could be the culprit.
Z06scentair is offline   Reply With Quote
Old 07-21-2014   #3
Kevin
Kevin's Avatar
are you sure the wires are seated on the coils? Had this issue myself I replaced the coils and the wires kept coming off on two coils, changed wires and the problem went away
Old 07-21-2014   #4
larry.schenk
I am afraid that the module is the issue, took it all apart again and check and double checked the wiring and conections and still same exact issue. Wish I could just try another module just to see if is it.. anyone know someone that has one to try????
Old 07-21-2014   #5
Z06scentair
Bob Sweeting has a used for sale I believe. Trying to acquire contact info for you.
Old 07-21-2014   #6
Kevin
Kevin's Avatar
if it is the dis you're looking at around $600
Old 07-21-2014   #7
larry.schenk
Thanks Z, would have to buy one if I knew that was the problem for sure, wonder if he would rent to buy so I could rule it out or in ;-)
Old 07-21-2014   #8
USAZR1
USAZR1's Avatar
Buy it from Bob and see if that's the problem. If not,sell it to someone else.
Seems like someone is always looking for that part.
Is there no way to correctly troubleshoot the DIS module?
Old 07-21-2014   #9
Kevin
Kevin's Avatar
http://www.zr1specialist.com/HAT%20W...n%20module.htm
Old 07-21-2014   #10
larry.schenk
Good advise, just might have to do that..
