Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes (pre-production)
Old 04-16-2010   #1
1989ZR1#74
Default 1989 ZR-1 #080, Mike Yeager's
I have been in contact with Ed Carleton about #080. I met Ed at Barrett Jackson this year after I won #004. He is going up to Effingham next week to work and Mike Yeager's 89. Their goal is to get the old girl running again. Ed is not yet a member here, but I am encouraging him to sign up and keep us updated on the evolution of #080.
#080 was found at the Lotus Graveyard and was restored using a donor car:
Ed is going to try and make it to BG next month
Ed the floor is yours....
Eric
1989ZR1#74 is offline   Reply With Quote
Old 04-16-2010   #2
1989ZR1#74
Default Re: 1989 ZR-1 #080, Mike Yeager's
Some notes form Ed:
"Then Lingenfelder installed the power train, and Gordon did some wiring."
"The area I am most interested in is the DCM connector. Thats the module on the underside of the intake plemumn, and the 2 ten pin connectors just behind the passenger dash area. I would appreciate any help you might have in getting this Beast running again."
Tyler, what are the differences between a 90 DCM and an 89??
Old 04-20-2010   #3
Tyler Townsley
These will help. You need to compare them to the 90 ecm diagram. I offered some time ago to help but the people seem to keep changing.
http://deliquescence.net/~tyler/prototype1/89_p_506.jpg
http://deliquescence.net/~tyler/prototype1/89_p_507.jpg
http://deliquescence.net/~tyler/prototype1/89_p_508.jpg
http://deliquescence.net/~tyler/prototype1/89_p_509.jpg
http://deliquescence.net/~tyler/prototype1/89_p_510.jpg
http://deliquescence.net/~tyler/prototype1/89_p_511.jpg
http://deliquescence.net/~tyler/prototype1/89_p_513.jpg
One need to be very carefull mixing 90/89 ecms and dis modules, and making sure the fuel pumps are connected properly.
Tyler
Old 04-21-2010   #4
1989ZR1#74
Mike may bring #080 to the Gathering. Wow would I love to get #074 there too. Going to be a lot of early cars there
Old 05-01-2010   #5
zedrone
best of luck! What is the issue with it not running?
Ed
zedrone is offline   Reply With Quote
