Old 03-02-2010   #1
RICKYRJ1
RICKYRJ1's Avatar
Default DYNO Pulls
Anybody going to do any Dyno pulls in BG? This was not offered last year and I think it is a cool idea. I have never done one, what is the procedure? do you run it through the gears?
Thanks
Old 03-02-2010   #2
flyin ryan
flyin ryan's Avatar
Default Re: DYNO Pulls
Thanks
Just until you get to 4th.
Old 03-02-2010   #3
xlr8nflorida
xlr8nflorida's Avatar
Thanks
Mine has been done a few times. Once you know though, I don't see the point unless you have made more mods etc and need to retune.
This is not my car.
http://www.youtube.com/watch?v=drbFmqJIMMU
Old 03-02-2010   #4
QB93Z
QB93Z's Avatar
Rick,
Two years ago the dyno pulls were done at a local (near the NCM) tuner shop. You go there with your car and wait your turn. The dyno operator will direct you to position your car in the test area. Then it is secured with straps so that the rear wheels (for a ZR-1) are sitting on a large roller in the floor. The operator makes a few simple connections to the electrical system of the engine. Then the operator starts and operates your car from idle to full rpm to perform the test. Usually there are three runs. Then the operator gives you a print out of your data.
I recommend doing it for your car since you just got done making mods. I'll go over with you, I would love to hear your car scream.
Old 03-02-2010   #5
Personally, I'm dubious when it comes to putting the car on just any ol dyno. We've all seen too many variations between machines with no changes to the car's setup. Why would that be if the operator dialed in the correct conditions before the run? Good question. Did conditions change during the day? What affect would a 30? change in temp (between morning and afternoon) make in otherwise identical runs?
Call me paranoid, but I'm thinking I'd rather restrict my runs to one machine at one shop where I'm reasonably sure the operator knows his stuff.
YMMV,
P.
Old 03-02-2010   #6
xlr8nflorida
Agreed, plus sometimes the straps break, motors go boom etc, cars jump off dyno wheel.
If you look at the videos on you tube, you would never dyno your car LOL
http://www.youtube.com/watch?v=oGaXtdW_NNo
My car has only been dyno'd by the same performance shop.
I'm sure the NCM will have a safe setup though and a good operator.
Old 03-03-2010   #7
GrayZ
In the last few years in Bowling Green they have offered a couple of different types of dyno. One was a local speed shop, which, Marc Haibeck
burned a chip for Ron.
the other is a a dyno truck, that is set up at the museum, I dyno'd on that particular setup 3 years ago. Either way, its nice to know your numbers, and perhaps find a few extra ponies with a few small, tweaks.
I'm just sayin
GrayZ is offline   Reply With Quote
Old 03-03-2010   #8
xlr8nflorida
I'm just sayin
Absolutely, especially with Corey, Marc etc on-site.
Marc did my chip.
