Old 09-07-2017   #41
Roadster
Roadster's Avatar
Default Re: Changing the spark plugs.....
YIKES!
IIRC, plugs only require (something like) 19 ft# of torque. Stripping the aluminum threads immediately came to mind - even if they are "only siezed".
On installation, I dab the tip of a finger in some anti-sieze goop, and make a single swipe (perpendicular to) across the threads before reinstalling the plug.
In 55 years of changing plugs I've never had one back out, nor require more than a gentle push on the ratchet handle to break it loose. (And, once the initial torque is broken, the plug usually unscrew with twisting the extension with my fingers...usually.)
Obviously, those threads didn't strip out; no harm done. But, I know you'll like the anti-sieze when you remove them next rime.
Yea, when I went to undo I said much more than YIKES!.....one of the PO's really wanted to make his strength known in the future.....I have used this size breaker bars enough to now have the feel of how much pressure to apply when getting something loose. As mentioned, I wouldn't do this to another owner's vehicle even if asked....if I mess up on my own vehicle, oh well!!! but as you can see, they came out fine. I did use a slight amount of anti-sieze for the next time....
I started usng a dab of oil instead of anti-seize. W anti-seize I found that I needed to snug up the plugs fairly often.
I have never used oil for this purpose, not saying it wouldn't work....and have not performed a snug-up on the plugs, yet!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-09-2017   #42
Hib Halverson
Anti-seize or oil works well on plug threads but if you use anti-seize compound you MUST use non-metallic anti seize.
Much of the anti-seize on the market has copper, moly or nickel in it so read lables before you buy.
My favorite for spark plugs is DuPont Krytox a flourinated grease which has anti-seize properties and is very durabile at high temperature.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 09-09-2017   #43
Roadster
Roadster's Avatar
Thanks for the tip.....I will have to check my supply.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
