#31 |
![]() Join Date: Feb 2011
I would check all hoses outside the plenum first, before pulling it. There is this one hose that comes out and over towards the radiator reservoir on the passenger side in the nose. It has a connection that passes over the top of the AC hoses. It comes loose if you were working in that area.
#32 |
![]() Join Date: Aug 2006
1- Got into it in 1st gear getting the r's close to 5k, and it felt like the accelerator pedal kicked back towards my foot. Shifted into 2nd & 3rd, brought the r's up again, was fine. Tried it again after a mile or so, did not do it that time. All future heavy throttle in 1st gear did not duplicate the kickback. Thought that was kind of unusual....
Are you sure this is not ASR activating? 2- I noticed that when the plenum pull was done, and the vacuum issues were addressed, when first turning the key to the on position to hear the vacuum pump, it only came on for about 2-3 seconds. Today when first started, it stayed on for 3-5 seconds. All repeat "hot" starts just turning the key to the on position did not activate the pump at all. This type of variation is not unusual. I wouldn't worry about this. 3- Reason #2 has me concerned is that the idle is still not quite right. And at one time today, it did go as high as 1200 r's when I came to a stop. Sometimes it will idle at 650-700 r's when stopped, other times it will be at 900-1000 r's when stopped. We'll investigate when we have our WAZOO meet. |
#33 |
![]() Join Date: Mar 2014
"Are you sure this is not ASR activating?"
It very well could have been the ASR activating....didnt even give it a thought, as there was some salt dust still on the road... "This type of variation is not unusual. I wouldn't worry about this." Yea, that's me always thinking of something... "We'll investigate when we have our WAZOO meet." Sounds good to me.... Sent from my SM-G935P using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 03-13-2017 at 09:07 PM. |
#34 | |
![]() Join Date: Sep 2008
That sure sounds exactly like the description of how the ASR feels when it decides to meddle in your fun in order to rescue you from wheel-spin. My car used to routinely invoke the ASR as I passed through 5500 rpm, as the tires would begin to break loose. To confirm you could replicate it with ASR off, but I do not really recommend that. Perhaps your new secondaries, plugs, etc, are now providing you with a lot more power than before. Try lighting them up during launch, and see if the pushback that you will feel on the accelerator is the same. If so, it's a good thing! You are making too much power for the tires! ![]() Marty |
#35 | |
Now since the secondaries are operational, I noticed the Z gets really loose at that 5500 rpm range , and even more so now with the new spark plugs. And of course already having Marc's chip in there with that extra 10 HP in addition to the parameters it enhances, my LT5 just runs sooooo good!!! Yes, I agree I am making too much power for the tires.... ![]()
#36 |
you're right, those 41-963's don't look very good for that mileage. the original 41-407's were supposed to be good for 100,000 miles, i thought. i'm having a hard time sourcing a good stock plug right now, NAPA gave me a set of AC R44LTS6's they say match the '95 "double ovhd cam" model, but i can't find anywhere something that says they're acceptable plugs. btw, do you know how to get in contact with Jim Voter fm WAZOO?
#37 | |
You can PM Jim....his screen name is....QB93Z, I will PM his cell # to you....
#38 |
![]() Join Date: Nov 2007
IIRC, plugs only require (something like) 19 ft# of torque. Stripping the aluminum threads immediately came to mind - even if they are "only siezed". On installation, I dab the tip of a finger in some anti-sieze goop, and make a single swipe (perpendicular to) across the threads before reinstalling the plug. In 55 years of changing plugs I've never had one back out, nor require more than a gentle push on the ratchet handle to break it loose. (And, once the initial torque is broken, the plug usually unscrew with twisting the extension with my fingers...usually.) Obviously, those threads didn't strip out; no harm done. But, I know you'll like the anti-sieze when you remove them next rime. ![]() Last edited by Paul Workman; 09-06-2017 at 09:35 AM. |
#39 |
I started usng a dab of oil instead of anti-seize. W anti-seize I found that I needed to snug up the plugs fairly often.
#40 | |
Speaking of "plugs" seizing, I always use either Teflon (plumber's) tape or anti-seize on the various drain plugs; e.g., oil pan drain/fill plugs. That really does the trick - far as seizing goes. ![]() ![]() |
