Old 03-09-2017   #1
Roadster
Roadster's Avatar
Default Changing the spark plugs.....
Removed all of the spark plugs tonight, and were they ever in there!!!! very tight to say the least. Ended up combining what tools I already had, one that was recommended by many on the forum and a few I found that could help me out with removal.
Number 8 plug of course was the hardest, with number 6 being next in line. Both these two and all of the others needed some "gentle persuasion" to remove. You might have thought Superman installed them. Apparently that person did not use any anti-seize. From what the PO said that was before the previous PO, these plugs have been in there for 12-15000 miles.
They are AC 41-963's. They appear in decent shape for the mileage, but also may have some slight issues. Checking the gap, they were @ .050 and some were a little wider.
Some of the tools used....
The one on the left is the 5/8" with the swivel. The one on the right is a magnetic socket with a built-in extension...
the magnet worked great when a plug didn't want to come out...
the socket on the right is over 5" long and fits flush with the top of the head....you feel more comfortable with it because it is longer and therefore has better leverage...JMO
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-09-2017   #2
Roadster
Roadster's Avatar
Default Re: Changing the spark plugs.....
also used some wobble extensions trying to find the best combo for #'s 6 & 8.
one of the tough ones....glad they are all out.....whew!!!
the final combo for #8...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-09-2017   #3
Roadster
Roadster's Avatar
Some of you may agree or may disagree....I wasn't about to throw my back out removing spark plugs....so when I felt that they were in there really tight, resorted to one of my leverage tools. This time only a half of a floor jack handle. No room for the whole thing....lol I wouldn't do this on anyone else's vehicle, but for me it broke most of the plugs loose. Only two I undid by hand. The others needed persuasion......
Spark plugs from Left to Right.....
#8 #6 #4 #2...
you can see oil at the top of the threads on 3 of the plugs...
#7 #5 #3 #1...
oil at the top of all of the threads...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-09-2017   #4
ssrszz4
So what plugs did you put back in?
ssrszz4 is offline   Reply With Quote
Old 03-10-2017   #5
Roadster
Roadster's Avatar
Not any yet.....but either tomorrow or tomorrow night these will be going in.
NGK 3690 Iridium IX Spark Plugs (TR7IX)
Went with Hib's recommendation of going two colder ranges than the stock range which may be too hot for our engines.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2017   #6
Part of the AC box is removable to help assist in the removal of the firewall passenger side plug.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 03-10-2017   #7
Roadster
Roadster's Avatar
I did read that at one time or another, but forgot about it at the time and really wouldn't have wanted to remove any additional parts. Just took me a few minutes to try out different combos for #6 & #8 than what was already mentioned. The biggest problem was the tightness of the plugs. Once I broke them loose, not a problem. Will have to look up the spec for install, they for sure are not going in as tight as before!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2017   #8
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Tom!
As always, THANK YOU for sharing all that you do!
Your descriptions are succinct and easy to understand.
However, the real highlight is your picture taking!
All of the right shots, that also explain visually the methodology used!
It is you and the others that take the time to do this, that gives other owners, particularly, newer ones, the confidence to tackle these jobs!
Marty
Old 03-10-2017   #9
Roadster
Roadster's Avatar
Originally Posted by DRM500RUBYZR-1 View Post
Tom!
Marty
Thanks Marty, your reply is very much appreciated.
Lol....yes there is a method to my madness....lol
I try to give as much as a visual as possible, maybe an individual who has never attempted anything before, would be willing to give it a try between the pics and other members advice, would get them through it...btw, I liked the extended breaker bar pic the best!!! lol
Doing some research, it seems that the anti-seize is not really needed, but to use a very light coat of oil instead. I also found that the torque of the plugs should be 15 lb.ft
I rather check for re-torque if necessary rather than overtighten.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2017   #10
G8nightman
G8nightman's Avatar
Looks like you can use caters fuel line clamps yours is broken :-)
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
