Old 09-04-2009   #41
tccrab
tccrab's Avatar
Default Re: bad stutter at 2000 rpm, only power key on
Typically, bad fuel injectors cause symptoms such as a missfire at idle, rough running at a constant RPM and a loss of power when the secondaries are opened. It all depends on which injector(s) go bad.
When a fuel injector's internal coil goes shorted, it usually causes the injector to stick in one position. That position could be wide open fuel, partial fuel, or no fuel at all.
A bad primary injector will cause misfire at lower RPMS that goes away when the secondaries open.
Secondary fuel injector(s) failure will cause a loss of power which usually manifests itself when you can't feel much a difference between Full Power mode and Low Power mode on the Valet Switch.
Your situation as you describe it, sounds like the engine goes either rich or lean during the transition time between High Power mode and Low Power mode, which clears up as engine RPM increases.
TomC
"Crabs"
Old 09-04-2009   #42
TomC
"Crabs"
Are the secondary injectors and primary injectors the same on a 1991 ZR1? What are the RC #s for primary and secondary injectors for a 1991 ZR1? Where is the best place to get RC injectors?
Old 09-04-2009   #43
Jeffvette
RC 205 or RC 210. You can only get them from rc directly. www.rceng.com
They will cut the injector for the differences in the primary and secondary.
I personally recommend accel injectors.
Old 09-04-2009   #44
What are the Accel #s for secondary and primary (1991 ZR1) and where can I them?
Old 09-04-2009   #45
Spanky1965
So Jeff can I ground the pink wire and drive the car to see if it helps?
Spanky1965 is offline   Reply With Quote
Old 09-04-2009   #46
tccrab
tccrab's Avatar
Jeffie'll get 'em for you.
He's the MAN!!!
TomC
"Crabs"
Old 09-04-2009   #47
tccrab
tccrab's Avatar
Hmmm..... Good question.
Better wait for Jeff to answer this one.
I'm guessing it might cause a lean condition, but maybe not.
Tomc
"Crabs"
Old 09-04-2009   #48
I am assuming you are then confirming that the ECM is good or bad? If it helps you are assuming that the secondary is not opening when they are controlled through the ECM? I do not know how this is different than guys/gals tying their secondary open. I would assume it would start out lean but I guess they are also modifying the secondary injector control.
I am just trying to figure how this all works It just takes time for some dunderheads like myself
Old 09-04-2009   #49
He's the MAN!!!
TomC
"Crabs"
Old 09-04-2009   #50
Spanky1965
well my thought was if you can remove the system why cant you run with it grounded open???
