![]() ![]() Runs perfect under normal power, but turn on the power key and idle goes up, and at exactly 2000 rpm's at part or full throtle it sounds like it stutters, bad, clears up at 5500 and pulls hard to 7500. ![]() |
just wanted to add the car sat for 3 years before i got it, it has 30,000 miles, and had the vacum line that runs to the comp on the drivers side disconected.
Try this test:
Turn the Engine Power Key to off. Run it hard, all the way up to 7000. Turn the Engine Power Key to On. Do the same thing. You should notice a significant difference in power between the settings. If there's only a slight difference or no difference at all, your secondaries system is suspect. Injectors, secondary actuators, secondary vacuum components will all cause symptoms like these. The fun part is figuring out which. Here's everything you should ever need to know about your secondary port vacuum system: http://www.corvetteactioncenter.com/...diagnosis.html Good luck! TomC "Crabs" |
thanks Tom, the funny thing is there IS a big diff, not even close. also the vac pump runs for 3 sec and does not cycle on and off so i am assuming no vac leaks
#5 | |
Narrows it down a tick. Your secondary actuators could be sticking and then opening later than they should. That would cause a mid rpm bog as the fuel mixture goes rich and then once they're open, the power comes back as the mixture leans out. It could be fuel injectors, if you've got secondary fuel injectors that aren't flowing like they should, it could cause a bog. Coils can cause stumbling problems, check out this 3 year long horror story: http://www.zr1netregistry.com/forum/...ead.php?t=1777 Doesn't sound like your problem though, my first guess would be fuel injectors, secondary actuators next. TomC "Crabs" |
I agree, but can you test the secondary actuators without removing the plenum?
![]() Join Date: Mar 2007
Is the 2ndry MAP sensor under the ECM connected?
yes it was diconected when I got it, but my friend did not drive it like you or I would, so not sure he even noticed. I have conected it
#9 | |
![]() Join Date: Dec 2004
![]() I'm not sure if that will work. ![]()
#10 |
I bet your secondary throttle plates are not opening up or vacuum/injector problem. This stuff is generally easy to fix if you understand the system.
Here is a start.http://www.corvetteactioncenter.com/...diagnosis.html |
