Old 06-07-2009   #41
gbrtng
gbrtng's Avatar
Default Re: Correct engine coolant temperature
Originally Posted by USAFPILOT View Post
At what temp would damage to the engine occur? That seems to be more important than who's car runs the coolest and why?
Some years ago at an annual NCM ZR-1 Dave McLellan mentioned one of the prove-in tests was running 50 miles with a ruptured/cut coolant hose. He said the ECM goes into a limp-home mode where it cycles through alternate cylinders to keep the block temperature below meltdown but still provide some useable power. So there is some margin of safety above and beyond the factory thermostat and fan temperature settings.
Old 06-07-2009   #42
salvatore1
Actually I discovered the main cooling fan (drivers side) was siezed up. All I had to do was replace the motor (cost $31 at napa) - problem solved.
salvatore1 is offline   Reply With Quote
Old 06-09-2009   #43
JAX S50
JAX S50's Avatar
I just pulled the radiator today and boy what a surprise about 50% of the area was blocked, anyway time for a new one where is a good source to get one?
JAX S50 is offline   Reply With Quote
Old 06-09-2009   #44
dbriana
Do you want another factory one or an aluminum dual core that cools much better?
dbriana is offline   Reply With Quote
Old 06-09-2009   #45
JAX S50
JAX S50's Avatar
Here is what I found yesterday
Old 06-09-2009   #46
JAX S50
JAX S50's Avatar
Well I was thinking the factory one because I heard that the dual core dosen't cool very well at low rpm/speed ???
Old 06-09-2009   #47
dbriana
If you are going to replace it I would go with a DeWitts. It will cool much better, don't think it will matter about low rpm/speed.
Old 06-09-2009   #48
QB93Z
QB93Z's Avatar
I have replaced the radiator in two ZR-1's in the last year. I went with a DeWitts in one and a Ron Davis in the second one. I believe that the C4 radiator for manual transmission cars is NLA.
Here are some links to previous discussions:
http://www.zr1netregistry.com/forum/...ead.php?t=7737
http://www.zr1netregistry.com/forum/...?t=3713&page=2
Old 06-10-2009   #49
Just a fwiw, Jim is correct our manual trans specific radiators are NLA from GM. The OE /GM replacement part is the auto trans radiator application. People, like GC aka Daryl, have used them and noticed no cooling issues with the trans cooler in the right side tank.
