Where can I find a replacement for the throttle cable clamp that holds the cables down across the plenum? Thanks for your help,
Should be a dealer item, I'll get you a part number in a hour or two.
Discontinued.
But I think I have a source for them. |
Thanks. I appreciate your help. I've seen on several Zs that these clamps have been either painted or powdercoated. Which is it?
![]() Join Date: Jul 2004
Mine are bare steel
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
They are bare but have the same protective coating on them that the small pipes do for coolant and the PCV system.
![]() Join Date: Apr 2004
I also need one of these clamps, as well as the small torx screw that holds it in place. Let me know when you find one!
Thanks, JohnnyB |
Found the Throttle Cable Clamps. Kurt White has them! Alll of them!
$10.00 each! JohnnyB FASTZR1 |
