-   C4 ZR-1 Parts For Sale / Wanted (http://zr1.net/forum/forumdisplay.php?f=10)
-   -   Throttle cable clamp (http://zr1.net/forum/showthread.php?t=1182)
crazyb1 12-07-2005 09:37 PM
Where can I find a replacement for the throttle cable clamp that holds the cables down across the plenum? Thanks for your help,
Jeffvette 12-08-2005 02:55 PM
Re: Throttle cable clamp
Should be a dealer item, I'll get you a part number in a hour or two.
Jeffvette 12-08-2005 05:07 PM
Discontinued.
But I think I have a source for them.
crazyb1 12-08-2005 06:47 PM
Thanks. I appreciate your help. I've seen on several Zs that these clamps have been either painted or powdercoated. Which is it?
phrogs 12-09-2005 03:27 PM
Mine are bare steel
Jeffvette 12-09-2005 04:29 PM
They are bare but have the same protective coating on them that the small pipes do for coolant and the PCV system.
FASTZR1 12-10-2005 08:58 AM
I also need one of these clamps, as well as the small torx screw that holds it in place. Let me know when you find one!
Thanks,
JohnnyB
FASTZR1 03-24-2006 10:46 AM
Found the Throttle Cable Clamps. Kurt White has them! Alll of them!
$10.00 each!
JohnnyB
FASTZR1
