Old 04-10-2008   #1
Sodak52
Sodak52's Avatar
Smile Hurst Shifter
I've purchased a Hurst shifter for the ZR-1 and need a little advice on installation of the shifter. I remember seeing a Thread sometime in the past showing how to install it, but can't find it. Any help would be much appreciated.
Sodak52 is offline   Reply With Quote
Old 04-10-2008   #2
kenthompson
kenthompson's Avatar
Default Re: Hurst Shifter
One, open the box and make sure the bearings are in the shifter. If they are not, let me know and i'll give you the Timkin bearing number to order.
After that, read the instructions and read the FAQ here.
It's really rather simple to do. Just a PITA to get everything out of the way.
KT
kenthompson is offline   Reply With Quote
Old 04-10-2008   #3
tccrab
tccrab's Avatar
There is a write up (with pics) by Johnny "Phrogs" over on that "Other Forum Who Shall Not Be Named".
http://forums.*************.com/show....php?t=1063558
You will have to cut and paste and edit the link for it to work.
It's obvious what part is missing.
Good luck!
Old 04-10-2008   #4
DMark
DMark's Avatar
Originally Posted by tccrab
There is a write up (with pics) by Johnny "Phrogs" over on that "Other Forum Who Shall Not Be Named"......
That is the write up I used and everything went great. Johnny also replied to my PMs with helpful hints.
DMark is offline   Reply With Quote
Old 04-10-2008   #5
Sodak52
Sodak52's Avatar
I found the link. Thanks alot. This should help alot. I'll let you know how it goes this weekend.
Old 04-10-2008   #6
Good luck!
Chevetteforum right?
Old 04-10-2008   #7
Sodak52
Sodak52's Avatar
Yes, it was in the Forum under Archived links.
Old 04-12-2008   #8
PhillipsLT5
PhillipsLT5's Avatar
Contact
www.zfdoc.com
Old 04-16-2008   #9
vettepilot
Thanks for the info about checking for bearings. Sure enough mine didn't come with any although the box said it did. Please let me know the Timken numbers
KT
vettepilot is offline   Reply With Quote
Old 04-16-2008   #10
karterdon
karterdon's Avatar
Double check your shifter again - There should be a small needle bearing cage on each side of the shifter body. I just got one from Jeg's - and the bearings are there. I can't see how they would be missing - They are press fit.
Don Yoakem
91-#267 Dark Red Met.
karterdon is offline   Reply With Quote
