Old 02-14-2025   #21
scorp508
Default Re: Question on Sound Deadening Material for Interior
As said above, depending on goals you may need multiple products. Using the Dynamat brand as an example...
Dynamt Xtreme will reduce rattles/vibrations.
Dynamat DynaPad will reduce heat and road noise.
While many of us do, you don't need to cover the entire interior with Dynamat Xtreme (or similar other brand product) to get a reduction of vibration. Some people just place squares of it in various places and even if an uncovered spot vibrates the nearby squares will absorb it. I'm guilty though as I have my 87's interior covered in it. Haven't reassembled yet to see how it did.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
scorp508 is offline   Reply With Quote
Old 02-14-2025   #22
This might help
https://www.diymobileaudio.com/threa...-guide.463283/
Old 02-14-2025   #23
HAWAIIZR-1's Avatar
Thanks Jeff! This was the best explanation I have ever seen and totally understand now.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
