Old 02-02-2025   #1
RICKYRJ1
RICKYRJ1's Avatar
Default Question on Sound Deadening Material for Interior
Hi, I'm in the process of covering plastic interior trim pieces in Nappa leather.
I want to cover the underside of the pieces in Dynamat or like product. Anybody see any kind of issue with doing so,clearance, fitment ? So far i have the windshield header, A pillar, B pillar, Halo, and the 3 rear cargo pieces wrapped. They look great and feel so much better. LMK Thanks Ricky
Sorry I see this is in the WRONG section, MODS, Please move Thank You
Old 4 Weeks Ago   #2
ABBEZR1
ABBEZR1's Avatar
Default Re: Question on Sound Deadening Material for Interior
When you get finished, please post some pics...thinking about doing the same thing...
_______________________
1990 Bright Red/Black #946
B and B X-Pipe
Stainless Works Long Tube Headers
Cat delete
49th Street Rockers
Haibeck Chip and Tune
ABBEZR1 is offline   Reply With Quote
Old 4 Weeks Ago   #3
I used Dynamat for the floor areas behind the seats in the '93 ZR-1 and in my 2016 C7 Z06. I believe there was some improvement but not a huge amount. It is hard to overcome the noise our wide HP tires make on pavement. I have some pictures of what I did to the Z06. While I don't have pics of the ZR-1 work, they are essentially the same. Rather than do all the work myself on the Z06 (I am an old man), I took it to the nearby audio installation shop for Best Buy, who take apart interiors for a living. They did the work in 2016 for $100 as I recall, although I am sure it would be more now. But better than me doing it. --Bob.
Old 4 Weeks Ago   #4
What is your goal? less rattle type noise or to quiet the interior.. the deadening will help eliminate the sounds from vibration and rattling, it may help with sound but that is not it's main purpose. you will want closed Cell foam or other products to help quiet the noise down if that is your goal
Old 4 Weeks Ago   #5
secondchance
Hey Ricki,
I haven't tried what you are describing so can't say for sure but most likely, as long as you stay with thin sound proofing material (I thinkk 1/8" or less?), should be ok. For A pillar, B pillar halo, and rear cargo area deck, keep overlapping portions free of underlayment.
I bet these pieces covered in Napa leather looks fabulous.
Hope you come to Carlisle so that I can check it out.
Old 4 Weeks Ago   #6
These work really well. Exhaust has a nice mellow note with little to no drone.
https://www.earpeace.com/products/moto-pro
Old 4 Weeks Ago   #7
Ha Ha Dominic--Earplugs are a great idea. I still have a set that dates back to going to the Indy 500 in--wait for it--1971. (The one in which the Pace Car crashed into the photographers' stand in pit lane). The only time I currently use them is if we go to a movie theater because they seem to turn up the volume so much. Even being hard of hearing isn't enough to make it fun. --Bob
Old 3 Weeks Ago   #8
ZBrink
Forum Chairman
ZBrink's Avatar
As Jeff said, it would really depend on your goal. Wrapping the back side of the specific pieces you've mentioned would require a very thing material similar to Dynamat. However I'm not sure any results of doing that would provide you with any noticeable effect. But again, it would really depend on your goals.
Zack Brinkmeier - Forum Chairman, ZR-1 Registry
forum@zr1netregistry.com
1990 ZR-1 #299, Bright Red/Red
ZBrink is offline   Reply With Quote
Old 3 Weeks Ago   #9
secondchance
I think even thin product would reduce buzzing noise if a particular piece was buzzing. I applied 1/8? thick foil product on the transmission tunnel under the car and it reduced heat coming through substantially. Might have reduced the road noise a bit but not very noticeable since I didn?t do the entire floor.
Old 3 Weeks Ago   #10
RICKYRJ1
RICKYRJ1's Avatar
Yes Jeff, my goal is to limit the rattling from the cheap plastic. I would also like to have the door sound so much better when closing. I love the sound of the engine I never have the radio on. I drive at high RPM's than most so im always in the sweet spot. Another benefit of the leather is that it looks and feels sooo much better. Lower dash hush panels are next then onto the door panels in black leather & Alcantar with red stitching.
