View Poll Results: Do you like the new style LT5 Billet plate
Yes 13 65.00%
No 2 10.00%
Like it if thinner that this one 4 20.00%
Like the old style with the holes 4 20.00%
Multiple Choice Poll. Voters: 20. You may not vote on this poll
Old 05-05-2020   #11
EvanZR1
EvanZR1's Avatar
Default Re: New Style LT5 Billet Plate
Carter, sent you an email, but could you do one the dimensions of the entire TB? Then you could potential fit more text on it, and it would look "cleaner".
Old 05-05-2020   #12
carter200
carter200's Avatar
Evan,
Glad to see you are still kicking. I sent you back an email. Look forward to machining what you want. Take care.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-05-2020   #13
Mystic ZR-1
Mystic ZR-1's Avatar
How “thick” are they?
And, how thick would “thinner” be?
Thanks!
Mystic ZR-1 is online now   Reply With Quote
Old 05-05-2020   #14
carter200
carter200's Avatar
Thanks!
Little thicker than a quarter and they will not be any thinner.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-05-2020   #15
So if you have by-passed the TB coolant lines would you be able to put this on and it stay without the torx screws and it be level with the TB?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-05-2020   #16
tf95ZR1
tf95ZR1's Avatar
With or without coolant bypass, Looks like this just
"tapes" over the existing plate. That's why they
want it thin.
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 05-05-2020   #17
HAWAIIZR-1's Avatar
I would be interested in the same as you. Bypassed coolant, clean (no screw holes or cut out) and sitting flush w/ TB and stuck on with 3M heavy duty double stick. Carter would have to make it almost as thick as the original, but it’s not flat in there under the plate.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-05-2020   #18
carter200
carter200's Avatar
I could machine off material from your factory plate so the "new" style plate would fit flush or dang close depending on how low the factory torx set below the plate surface before machining. I can machine both the factory plate and screws if there was enough room.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-06-2020   #19
HAWAIIZR-1's Avatar
That’s a good idea. I forget what the stock plate looks like underneath? What about machining the thickness of new plate and tape off the top of the stock plate? Wait a minute! I’d have to see if I kept the stock plate the next time I go home. I probably tossed that nasty thing.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-07-2020   #20
Originally Posted by conesare2seconds View Post
I like it, though I might have flipped the logo.
Agree! Looks nice...very nice! (But, upside down to my eye too).
Tags
lt5, lt5 billet, lt5 billet plate, new lt5 billet plate
