Old 08-31-2017   #21
jrd1990zr1
jrd1990zr1's Avatar
Default Re: No heat from heater 1990 ZR1
Originally Posted by QB93Z View Post
John,
The Blend Door is controlled by a small electric motor and uses an electronic circuit to send position feed back to the AC Programmer. When the car is first turned ON, the AC Programmer sends a sequential full heat and full cool command to the Blend Door Motor. Since you are not seeing the movement, either the motor has failed, the AC Programmer has failed, there is a wiring problem, or the door is stuck.
I haven't investigated the access to the motor on a 1990 yet, but when you get to it, you can remove it and observe it's operation not connected to the door. And you can try to move the door by turning the pivot rod.
I have a complete set of the duct work from a 1991. I did not see it in the car so I don't know exactly how much you have to take apart to get to the motor.
If you need trouble shooting help when you get to the motor, call me. I will be glad to help.
Hi Jim,
I don't want to waste your time with a long phone call until I get deeper into this. I pulled the glove compartment, other than the top of the duct work not much to see Photo 1.
Pulled the lower hush panel (Photo 2 and 3) and low and behold looks like someone was there before. Radio receiver and associated wiring is all hanging loose (Photo 4). I see the duct work and the SIR wire but nothing that looks like an actuator or motor. Am I looking in the wrong places or not far enough into this?
Thoughts?
Thanks, John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 09-01-2017   #22
QB93Z
QB93Z's Avatar
John,
In your picture 1, the duct pieces you are looking at supply the air to the small vents that blow on the passengers knees. You have to remove those ducts to get to the top of the main air box that houses the Blend Door.
Keep digging and send another picture so I can get oriented with the 1990 setup.
Old 09-03-2017   #23
Originally Posted by jrd1990zr1 View Post
So Doug have you ever pulled the glove box to get the the heater box??
Just in case you want to pull your heater core without pulling the Dash.....
Replacing the Heater Core and Heater Hose Connection
Old 09-03-2017   #24
Mystic ZR-1
Mystic ZR-1's Avatar
So Doug have you ever pulled the glove box to get the the heater box?? Before I start ripping and tearing thought I would ask. How was Carlisle, wish I had gone.
Hi John
Fortunately, no! Never had to go in there.
Good luck with yours.
Missed ya @ Carlisle, nice time was had by all!
D
Old 09-08-2017   #25
QB93Z
QB93Z's Avatar
I just remembered something about the HVAC system that affected my trouble shooting. The HVAC programmer needs to be powered off (Battery disconnected) after any changes you make to the system.
You may want to try disconnecting the battery now and see if the system returns to normal operation.
Old 09-19-2017   #26
jrd1990zr1
jrd1990zr1's Avatar
Thanks Jim, I'll give that a try.
Had to but it back together so I could get the mandatory annual NYS inspection. While driving there it set a Code 09 on the AC, low freon, so looks like I have a slow leak. Last charged it 2 years ago. No heat and no A/C.
Looks like I've got a couple winter projects.
Old 11-04-2017   #27
jrd1990zr1
jrd1990zr1's Avatar
Since it looks like you have had your 1990 apart some questions on the heater core removal.
If you remove the heater box from the inside can you access the blend door actuator to replace it?
Did you have to remove the fuse panel to access the heater core box?
Thanks for the information. John
Old 11-04-2017   #28
jrd1990zr1
jrd1990zr1's Avatar
So I am back to trying to find the actuator for the blend door. I've removed the dash pad, lower hush panel, console trim panels, etc. Bought a fiber optic scope and still can not find the actuator.
Per the service manual, it looks like I need to remove the distribution duct which involves removing the fuse panel and instrument panel. Before I go forward I have to ask, does anyone have a better way to get to the blend door actuator rather than removing the entire instrument panel?
Below are photos of where I am now. I am really stuck, so please let me know how you have changed out the blend door actuator on a 1990.
Last question is the lower blend door pivot where the read arrow is pointing in the third picture?
Thanks
Old 11-04-2017   #29
I am not sure about the blend door but the CDM had to be removed....not the fuse panel.
Old 11-05-2017   #30
QB93Z
QB93Z's Avatar
Top of blend door duct from a 1991
