#11 |
![]() Join Date: Jan 2010
Yep, I see the glove compartment lid doesn't
fit well on your car either... Typical GM quality. Never seen one that's right. |
#12 |
![]() Join Date: Jul 2007
picture is not my car, but mine is the same way
#13 | |
![]() Join Date: Dec 2005
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#14 |
glove box is 9 screws I think.. Pretty simple
#15 | |
![]() Join Date: May 2007
The operation and diagnosis of the HVAC controls is (in the 1994 FSM) described in bits and pieces in Volume 1 and in Volume 2 and it takes a fair amount of research to figure it all out. Here is the Thread where I fixed my problem which may be similar to yours> http://www.zr1.net/forum/showthread.php?t=27542 Jim |
#16 |
![]() Join Date: Feb 2012
#17 |
As years progressed we got less space
First years (PRE-ABS) 2 full depth storage bins behind seats my 90 is full depth right and little tray on left I also have 94 panels so I have the glove bx AND the door storage
#18 |
John,
The Blend Door is controlled by a small electric motor and uses an electronic circuit to send position feed back to the AC Programmer. When the car is first turned ON, the AC Programmer sends a sequential full heat and full cool command to the Blend Door Motor. Since you are not seeing the movement, either the motor has failed, the AC Programmer has failed, there is a wiring problem, or the door is stuck. I haven't investigated the access to the motor on a 1990 yet, but when you get to it, you can remove it and observe it's operation not connected to the door. And you can try to move the door by turning the pivot rod. I have a complete set of the duct work from a 1991. I did not see it in the car so I don't know exactly how much you have to take apart to get to the motor. If you need trouble shooting help when you get to the motor, call me. I will be glad to help. Jim 443-244-1347 |
#19 | |
As always you're a life saver. Seems like this could be a big job and I hate to pull the car apart until the weather turns cold. I am going to pull the hush panel and glovebox over the weekend and see what I find. I've never been under that side of the dash. Thanks again, I'll let you know what I find. Best, John
#20 |
John,
Keep in mind the carpet part on the Pass side is part of the WHOLE Dash pad, there is the lower hush but it allows a limited view
