Old 02-07-2016   #31
ghlkal
ghlkal's Avatar
Default Re: Some Differences between 95's and 90'/91's
Interesting list Cliff
34. Selectable Data on SPEEDO LED.
What is different here?
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 02-07-2016   #32
You have to ask Demps as he had it on his list.
Originally Posted by Demps View Post
Windshield wiper to blade trunnion (different blades required)
Shocks
Shock gears
ASR & associated "stuff"
Master Cylinder
ABS (95 LT1 was upgraded & some say LT5 was too--can't remember)
Rear door jam "locker"--silver alignment pin
Rear storage compartments
Top wrench
No top bumpers (on inside frame) on 95s
Hood emblems & associated alignment holes
Selectable data on speedo LED
Old 02-08-2016   #33
Demps
Demps's Avatar
Can toggle digital readout for "gauges":
--oil temp
--voltage
--coolant temp
Ted
Demps is online now   Reply With Quote
Old 02-09-2016   #34
Wheels?
Old 02-09-2016   #35
lisounds
lisounds's Avatar
if we are talking about wheels then tire tread pattern also.
goodyear gatorback---vs---goodyear eagle gsc
lisounds is offline   Reply With Quote
Old 02-09-2016   #36
Fully Vetted
Fully Vetted's Avatar
Also, I believe 1990 was the only year for the 2 vertical gills.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-09-2016   #37
Demps
Demps's Avatar
95 seat belts unique
95 seat seam-stitching unique (double French)
