#11 | |
I actually applied engine degreaser and pressure washed the valley and the Larger Drain Port functions very well. I think if the Valley Drain Port on the 95' is not clogged with leaves that one could actually pressure wash the engine with no issues. I will add a photo of the Valley in a moment. Valley with New Crankcase Cover Gasket installed ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-30-2016 at 11:12 AM. |
#12 |
You forgot the door storage pods
#13 |
Is the hatch release backside of the passenger door still there? No Tire changing light either, Down in one window was on the 94 and up as well
#14 |
No Hatch release on passenger door but does have Hatch release on Key Fob.
#15 |
![]() Join Date: Aug 2006
I believe 94s and 95s have softer springs but firmer shocks. 94s and 95s are raised a bit more than early cars to keep softer springs from causing nose scrape. I thinks this is achieved by extra rubber pads on the underside, outer edges of the front spring.
#16 |
I dont recall an EGR on the 90. I'll look again....
1990 ZR-1 #642 |
#17 |
#18 |
![]() Join Date: Apr 2004
Windshield
#19 |
![]() Join Date: Jan 2006
Windshield wiper to blade trunnion (different blades required)
Shocks Shock gears ASR & associated "stuff" Master Cylinder ABS (95 LT1 was upgraded & some say LT5 was too--can't remember) Rear door jam "locker"--silver alignment pin Rear storage compartments Top wrench No top bumpers (on inside frame) on 95s Hood emblems & associated alignment holes Selectable data on speedo LED |
#20 |
![]() Join Date: Apr 2007
As Phil noted, go with a Hurst and eliminate the lift ring. I did that on my '93 and there is plenty of spring loading to keep you from putting it in reverse instead of fifth or sixth. Never had a problem and loved not having the lift ring. --Bob
