![]() Join Date: Sep 2012
I'm sure you did if you're from OK. This was my closest experience. Here's an idea about how close it came. The blue X is my house and there you can see the path of the storm. It was almost a mile wide and stayed on the ground for 4-5 miles.
All of the deaths from Garland your hearing about is where it crossed I-30 at the bottom of the pic. That's a small mix master at 190 and I-30 and it was blowing cars off of the top bridge which is about 80 feet high. Massive destruction here in Rowlett. I can't believe there were no deaths. I appreciate you guys checking in on us. It means a lot.
