Old 11-11-2015   #9
MuRCieLaGo
Default Re: Vacuum pump confusion
The vacuum pump provides supplemental vacuum to the secondary port throttle (SPT) system. Vacuum is also provided from the engine during normal operation. If your SPT system is tight, i.e. no vacuum leaks, it will hold the SPT system open for a short romp. When you let off WOT, engine will again provide vacuum.
With vacuum leaks, SPT will not open at all or slowly close, depending on severity of leak.
But I swear it doesn't run at all and I have done at least 8 WOT runs until 7k RPM and there's no issue. I thought that in these conditions the ECM would block my RPM to 3k...
Originally Posted by We Gone View Post
WOW.. Looks like water intrusion for sure. You may want to check all electrical connectors, clean and apply some dielectric grease to them.
I knew there was something wrong when I opened it and it was full of rusty water...
Originally Posted by Gunny View Post
ditch the secondaries, get a new chip from Marc, problem solved
This!
I own a RX-7 and I removed a lot of systems. Made everything easier.
I would like to remove that secondary system.
