![]() Join Date: Nov 2014
What oil and what viscosity are good for the LT-5?
I heard amsoil is good but you really can't get it at the local Auto zone.. How about the Mobil-1 brands? |
Mobil 1 high mileage in 10w30 here. I can buy it anywhere in the proper weight and Marc says it has enough zddp.
![]() Join Date: Apr 2007
I use Amsoil ZROD 10w30 it has enough ZDDP, seems goo.
lorne #1748
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! |
![]() Join Date: Apr 2004
![]() Join Date: Feb 2011
I mix 3 qts of Amsoil Z-Rod to 5 or 6 qts of Mobil1 that I get in jugs at Walmart. The additive package in the Z-Rod is overkill for our application, but I roughly figured out that my blend approximates the additives available in 1990's vintage oil. One 12 quart case of the Amsoil will last for 4 oil changes (3-4 years for me). I also choose to blend because it is a little pricey to run Amsoil.
#6 | |
![]() And I know Amsoil is the correct oil just because.......actually because Marc says so Engine Oil Technical Information I like to "treat" my LT5s with the best ![]() But then again....I am one to replace liners if I find a minor scratch or imperfection ![]() ![]() Amsoil AMO ZDDP specifications: Phosphorus 1265 ppm Zinc 1378 ppm Recommended for the LT5 engine. Also for other engines with high tension valve springs.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-19-2015 at 12:00 PM. |
The 5 quart jugs at Walmart come out about $5 a quart. ($24-$26 usually)
I buy more than one to minimize trips to witness the human circus. I also stock up on oil filters. |
I use CastrolGTX 10W-40 Diesel. It has the necessary amount of zinc and phosphorous needed. And I have been using it for nearly 4 years on re-ground cams. Lobes look new. Get it in the 5qt jugs.
I just wanted to let you know that I am an Amsoil dealer/distributor and can help with all your lubrication needs. I use it in my zr1. It is great stuff
