-   -   Engine oil (http://zr1.net/forum/showthread.php?t=24550)
Vette73 01-18-2015 07:04 PM
Engine oil
What oil and what viscosity are good for the LT-5?
I heard amsoil is good but you really can't get it at the local
Auto zone..
How about the Mobil-1 brands?
1990 quasar blue 01-18-2015 07:12 PM
Re: Engine oil
Mobil 1 high mileage in 10w30 here. I can buy it anywhere in the proper weight and Marc says it has enough zddp.
hiperf406 01-18-2015 10:14 PM
Re: Engine oil
I use Amsoil ZROD 10w30 it has enough ZDDP, seems goo.
lorne #1748
We Gone 01-18-2015 10:58 PM
Re: Engine oil
http://www.zr1specialist.com/HAT%20W...dern%20oil.htm
mike100 01-19-2015 10:10 AM
Re: Engine oil
I mix 3 qts of Amsoil Z-Rod to 5 or 6 qts of Mobil1 that I get in jugs at Walmart. The additive package in the Z-Rod is overkill for our application, but I roughly figured out that my blend approximates the additives available in 1990's vintage oil. One 12 quart case of the Amsoil will last for 4 oil changes (3-4 years for me). I also choose to blend because it is a little pricey to run Amsoil.
Dynomite 01-19-2015 11:40 AM
Re: Engine oil
I am thinking you can pick up Mobile 1 at Walmart for about $6 a quart. I get Amsoil 10w 40 delivered for about $10 a quart. I do not have to drive 5-20 miles to WalMart. And I do not have to concoct my own Oil Mix for the ZR1 ;)
And I know Amsoil is the correct oil just because.......actually because Marc says so Engine Oil Technical Information
I like to "treat" my LT5s with the best :thumbsup:
But then again....I am one to replace liners if I find a minor scratch or imperfection :sign10:
http://i287.photobucket.com/albums/l...129d0d14b0.jpg
Amsoil AMO ZDDP specifications:
Phosphorus 1265 ppm
Zinc 1378 ppm
Recommended for the LT5 engine. Also for other engines with high tension valve springs.
mike100 01-19-2015 03:51 PM
Re: Engine oil
The 5 quart jugs at Walmart come out about $5 a quart. ($24-$26 usually)
I buy more than one to minimize trips to witness the human circus.
I also stock up on oil filters.
XfireZ51 01-19-2015 05:10 PM
Re: Engine oil
I use CastrolGTX 10W-40 Diesel. It has the necessary amount of zinc and phosphorous needed. And I have been using it for nearly 4 years on re-ground cams. Lobes look new. Get it in the 5qt jugs.
Myt415 01-19-2015 07:32 PM
Re: Engine oil
I just wanted to let you know that I am an Amsoil dealer/distributor and can help with all your lubrication needs. I use it in my zr1. It is great stuff
