Old 08-14-2014   #1
Schrade
Default DMF; serviceable?
I have left from my automatic conversion my DMF.
Is it a serviceable unit? I'm about 99% sure it had broken springs, from lugging too low RPM's when I bought it - supposedly a common problem...
Is it trash, or list-able, on eBay?
It had about 31.6k on it when the conversion was done.....................................
Old 08-14-2014   #2
Default Re: DMF; serviceable?
My understanding is that they are not
LGAFF is online now   Reply With Quote
Old 08-15-2014   #3
Schrade
So is the thing a doorstop / trash?
Old 08-15-2014   #4
If its bad, then probably yes.....make sure its really bad though
Old 08-15-2014   #5
mike100
Mine knocks in one direction slightly. It only acts up when there is a misfire and sometimes when the engine turns off, it knocks once. I was able to find a much better used one which I'm saving for later. The spring that damps the accelerating direction is still good so I'm gonna run it for the duration of this clutch.
Old 08-15-2014   #6
Schrade
I think I read that the springs are supposed to absorb vibration at low rpm's.
I had to set torque convertor lockup over 45 for that vibration. Any lower, and the whole car would shake, even at speed.
