-   -   DMF; serviceable? (http://zr1.net/forum/showthread.php?t=23550)
Schrade 08-14-2014 08:58 PM
DMF; serviceable?
I have left from my automatic conversion my DMF.
Is it a serviceable unit? I'm about 99% sure it had broken springs, from lugging too low RPM's when I bought it - supposedly a common problem...
Is it trash, or list-able, on eBay?
It had about 31.6k on it when the conversion was done.....................................
LGAFF 08-14-2014 11:07 PM
Re: DMF; serviceable?
My understanding is that they are not
Schrade 08-15-2014 01:19 AM
So is the thing a doorstop / trash?
LGAFF 08-15-2014 07:09 AM
If its bad, then probably yes.....make sure its really bad though
mike100 08-15-2014 09:42 AM
Mine knocks in one direction slightly. It only acts up when there is a misfire and sometimes when the engine turns off, it knocks once. I was able to find a much better used one which I'm saving for later. The spring that damps the accelerating direction is still good so I'm gonna run it for the duration of this clutch.
Schrade 08-15-2014 09:49 AM
I think I read that the springs are supposed to absorb vibration at low rpm's.
I had to set torque convertor lockup over 45 for that vibration. Any lower, and the whole car would shake, even at speed.
