This sounds a little crazy but my a/c works fine @ idle but when brought up to 1500 to 2000 rpms the light on the head blinks and goes into default. We pulled the fuses to reset and the a/c goes cold again @ idle. Any thoughts?
Did you pull any codes??
Normally flashing LED is a low freon indication
Freon is fine and line pressures are where they are supposed to be. We did not pull any codes. When the light flashed on the head unit to reset it there are 2 fuses you pull for 15 seconds and that resets the system. At idle the system operates as it should.
Could be the AC programmer above the acceloraor pedal on the firewall. However without running the code or the tests in the FSM (Factory Service manual) eveything is a WAG.
#5 | |
Is the AC programmer ZR1 specific? Thanks.... ![]() Last edited by louispf; 08-13-2014 at 10:06 AM. |
Well ok then. Good luck with your quest im sure TomTom can figure it out. GC
