Old 03-30-2013   #1
rkreigh
Default DRM Coil overs, spring rubbing half shaft
when I installed I noticed they were VERY close to the half shafts and had to jiggle the springs around to get just a bit of clearance
now that they have worn in a bit they are rubbing the half shaft slightly
does anyone have any tips on how to set these up and adjust them better?
getting just a bit of rubbing and not sure what to do to give more clearance
thanks!
Old 03-30-2013   #2
RHanselman
RHanselman's Avatar
Default Re: DRM Coil overs, spring rubbing half shaft
Ron,
I had two Z's do this. I solved the Turbo car's rub by installing new Poly Bushings on the Dog Bones. The old ones were dry-rotted and let them move under power... I suspect my Hawaii Ruby is the same. It just started last week...
Cheers,
Ron H
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 03-30-2013   #3
Most of us have replaced the dog bones altogether and installed heim joints with poly
Old 03-30-2013   #4
RHanselman
RHanselman's Avatar
Most of us?? Really...
Where do you get them?
Ron Hanselman
Founding Member #80
Old 03-30-2013   #5
thanks!
Ron,
That happened w mine when I re-installed them after doing rear end. Try loosening them up and turning spring so it gives a bit more clearance of half shaft. The springs don't sit symmetrically so you can twist them a bit to give you more clearance.
Old 03-30-2013   #6
Banski racing.
