DRM Coil overs, spring rubbing half shaft
when I installed I noticed they were VERY close to the half shafts and had to jiggle the springs around to get just a bit of clearance
now that they have worn in a bit they are rubbing the half shaft slightly does anyone have any tips on how to set these up and adjust them better? getting just a bit of rubbing and not sure what to do to give more clearance thanks! |
Re: DRM Coil overs, spring rubbing half shaft
Ron,
I had two Z's do this. I solved the Turbo car's rub by installing new Poly Bushings on the Dog Bones. The old ones were dry-rotted and let them move under power... I suspect my Hawaii Ruby is the same. It just started last week... Cheers, Ron H |
Most of us have replaced the dog bones altogether and installed heim joints with poly
Where do you get them? |
That happened w mine when I re-installed them after doing rear end. Try loosening them up and turning spring so it gives a bit more clearance of half shaft. The springs don't sit symmetrically so you can twist them a bit to give you more clearance. |
