Old 03-03-2007   #11
Jeffvette
Default Re: are there two different trans in zr-1's
Originally Posted by zr-1assassin
$1240.00-JUST TO PUT IT IN! does someone know what this SHOULD cost to have the clutch installed. no flywheel-just ACDELCO clutch kit i have? thanks guys
Should be 6 hours maybe 7 at most. It is rather time consuming.
Undo shift knob and other interior trim
Remove exhaust
Remove driveline
Remove C-beam
Remove trans
Remove clutch slave
Remove bellhousing
Remove pressure plate and clutch disk
Prep and clean surfaces
And install.
