Old 08-16-2011   #1
phrogs
phrogs's Avatar
Default Re: WTB: 1990 Cluster
Sorry man all out. They go pretty quick
JOHNNY P
Currently own
Old 08-16-2011   #2
limey
The 1990 & 1991 are different. the 90 oil temp gauge reads 260, the 1991 reads 280.
They may work, but they are different.
I'm off to the Corvette F0rum, sorry i tried.
Btw, if any of you old buggers find any 8000 Rpm clusters in Carlisle, buy them for me will you. I need only 90 & 91 MY's, all others not interested.
$300.00 for a used one, dead or alive.
limey is offline   Reply With Quote
Old 08-17-2011   #3
Kurt will a 92 Cluster work in a 91 with all the features of the guages function? Any clue? GC
Old 08-17-2011   #4
Short: No
Long:
the 90-91 LCD uses a different data pattern from the CCM then the 92-96. you could install a 92 ccm and cluster in your 91, I did on my dash conversion when I had a 91 dash in a 89. BUT I still did not have the extra digital gauges and I had a communication error between the CCM and ECM. you could possibly run a 92 MEMCAL in your 91, but I would verify that all the pins are the same. IF all the ECm pins are correct and you had the CCM, ECM, Cluster and MEMCAL for a 1992, it is possible that it will work.
That would be a cool thing to try, but keep in mind the CCM stores the mileage for the car as well
Old 08-17-2011   #5
Could be a cool thing to try, but keep in mind the CCM stores the mileage for the car as well
That can be fixed with a Tech-1A but I think the other other issues would be a bear to work through
