10-09-2009 | #1 |
Pad life
How long does the backing normally last on the polishing pads? I've got one pad that just gave up, while my other pads still secure just as they did from day 1.
10-10-2009 | #2 |
Re: Pad life
I think you might be in the wrong forum for this question
10-10-2009 | #3 |
Re: Pad life
Mind in the gutter again...... I like it!
10-10-2009 | #4 |
Re: Pad life
Rotary or orbital? It seems to me orbitals tend to beat up the backing plate more, though I'm not sure why.
The backing *should* last the life of the pad, though sometimes that's not the case. Who makes the pads you are using?
10-11-2009 | #5 |
Re: Pad life
I agree. Proly just a defective pad? Although a rotary just makes a circle. ROB's make the pad change direction constantly, maybe that puts stress on the backing vs the pad material?
10-11-2009 | #6 |
Re: Pad life
Pad life, Just don't go there !
10-11-2009 | #7 | |
Re: Pad life
It's an orbital and the pads are from Adams. The other pads I have are fine, it's just this one. |
10-11-2009 | #8 | |
Re: Pad life
Just FYI, but an interesting alternative is the Edge 2000 pads. They use a locking sorta system with no velcro. The pads cost a little more, but are double-sided. You can also change them more quickly, and they are self-centering (though with an orbital that matters less than a rotary). They used to be an independent company, but I think 3M bought them? Or I just can't find their website anymore...
10-12-2009 | #9 |
Re: Pad life
What specifically failed you?? Theres been some cases of people using the pads where the pad wasn't fully seated on the velcro and it kinda tore the velcro up. Its always best to take the palm of your hand and press hard into the center of the pad before starting.
In any event please contact our customer service so we can get to the bottom of this for you and get a replacement out asap. 866-965-0400
[CENTER][B]USE COUPON CODE: [SIZE="3"][COLOR="Red"]ZR1[/COLOR][/SIZE] TO RECEIVE 10% OFF YOUR NEXT ORDER AT [url]www.ADAMSPOLISHES.com[/url][/B][/CENTER] |
10-12-2009 | #10 |
Re: Pad life
Dylan, anytime I seat the pad I make sure to press down with my hand, or use the surface of the car as point to seat. I'll be more than happy to send the pad to you for an inspection.
Thanks! |
