Old 10-06-2009   #1
QB93Z
QB93Z's Avatar
Default Rear Leaf Spring found starting to splinter
Back in August while we were replacing the clutch in Darrin's 1990 ZR-1, we noticed that there was damage to the rear leaf spring. The damage appeared to be surface cracking but it was hard to examine. The only way we noticed it was that the exhaust system was off the car to pull the transmission. The car has 70,000+ miles.
Last weekend we replaced Darrin's rear spring and bushings. Thanks to Marc Haibeck for having a replacement spring available.
Easy job: Jack up the car, use two bottle jacks to "compress" the spring, remove the retaining nuts on the hanger bolts, remove the saddle bolts at the center of the spring and it is out.
Pics:
Over all view of the spring (spring is lying upside-down):
The damage was much more extensive that we thought from the visual inspection with the spring on the car. Close-up of left side of the spring showing damage:
Right side of the spring:
While we had the tools out, we replaced the spring bushings on my 1993 ZR-1 ,with 104,000 miles. These are the bushings we took off:
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 10-06-2009   #2
Default Re: Rear Leaf Spring found starting to splinter
Damn any telltale noises or issues before you saw the damage to the spring?
Old 10-06-2009   #3
ZR1Vette
ZR1Vette's Avatar
Damn... that is amazing. Just age or something else happening. Nice catch and work!!!
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 10-06-2009   #4
Before I had the Z, I had a 95, M6 coupe. One day I noticed it seemed to be listing about 3/4" toward the driver's side. On a hoist, sure enough the rear spring was doing the same thing on the driver's side. Changed it out - no big deal. My 90 Z is not delaminating as yet. But, I keep an eye on the springs every time I change oil or have any reason to be scooting under her.
Good catch!!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-06-2009   #5
Scrrem
Scrrem's Avatar
WOW....I've heard of these springs doing this, just never seen one. I'm amazed it didn't break altogether. Once I get my garage back in order, I think I'll put my car on jacks and do a once over.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-06-2009   #6
bdw18_123
Wow, that's crazy! Guess I better go check the one in my Z. Especially with 138K on the clock.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 10-06-2009   #7
QB93Z
QB93Z's Avatar
Darrin reported that there was no noticable ride quality issues. He drove it 900 miles to Bowling Green last May with no issues.
There was no body tilt before or after we replaced the spring. Maybe because both side of the spring had damage?
I don't believe that it is an age problem because there are a lot of these springs in service that are in perfect condition.
As stated in the Service Manual, DO NOT use cleaners or solvents on the springs.
Old 10-06-2009   #8
Jim where did you get the bushings? GC
Old 10-06-2009   #9
Jeffvette
Darryl, you can order most of the bushings you can order separately, but just order the complete kit and knock it out over the weekend.
Old 10-06-2009   #10
Jeffvette
Better thank Dwight, as that was the spring from his 90 when he went to coilovers.
