Old 10-06-2009   #1
Scrrem
Scrrem's Avatar
Default Floor Coating Complete
Well, after a four day event (prep, bond coat, final coat, finish coat) I finially got my garage floor coated using the UCoat-It system. Some of my more serious cracks in the slab didn't conceal as completely as I had hoped but with you really have to look close to see them. I'll let you know in a few months how it is holding up.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-06-2009   #2
secondchance
Default Re: Floor Coating Complete
Well Done Rich!
Doesn't the floor look a little bare? Is it not asking for a hydraulic.....
Old 10-06-2009   #3
QB93Z
QB93Z's Avatar
Your garage floor looks great Rich.
Old 10-06-2009   #4
Very nice ugrade for your man cave.=D> I wish I went with U Coat it too.
Old 10-06-2009   #5
Eric870
Eric870's Avatar
I've been thinking about coating my floor. Let us know how it holds up...
Eric870 is offline   Reply With Quote
Old 10-06-2009   #6
ZR1Vette
ZR1Vette's Avatar
Rich...
Great to see..know you wanted to do this big time. Now you know what is next... weighs about 2000 lbs and has four legs
Make sure you use the clear plastic sheets under your tires for as long as you can...more cure time better the job.
For the question of durability of the UCoatIt system...
I did the install about 5 years ago and here is condition overview>>
And yes there are a few spots where the finish released....and I will repair that>>
Old 10-06-2009   #7
Nicely done!
Old 10-06-2009   #8
Scrrem
Scrrem's Avatar
Originally Posted by ZR1Vette View Post
Rich...
Thanks Michael, Yeah...Yeah..one thing at a time. Now I need to get a utility shed so I don't have to put back all the crap I removed from the garage to get I looking this empty
Plastic under the tires.....that a good suggestion, I didn't think of doing that. I put the clear coat on a bit thicker that yours, so hopefully it will fair better.
Rich
Ron Davis Radiator
Old 10-06-2009   #9
Jeffvette
That is from the heat in the tires. Always try and park the car outside for a bit and let them cool off.
I just helped a neighbor do his three car garage, lot of work, but fairly easy.
Old 10-07-2009   #10
That looks so sweeet Rich!
I have a bad case of garage envy....
