10-05-2009 | #1 |
WAZOO Parts Inventory
Parts update: A new starter and alternator available w/ Scott Frager added.
These parts are available to any area folks in need or testing purpose. Updated List - 04/12/2010 Alternator (needs rebuild) 1 Yun Belt, sepentine 1 Jim Brake master cylinder and resovoir (used) 1 Jim Bolts, Coolant Tube(black oxide allen head) 32 Bob (Aurora40) C Beam Plate (T & B) 1 Jim Coolant Bottle Cover, Red 1 Rich Coolant Hoses, Stock, NIB 1 Rich DIC 1992-1993 1 Jim ECM, 1995 1 Jim Engine Full Power Key Module (1991-1995) 1 Jim EPROM, stock, 1990 1 Jim EPROM, stock, 1990 1 Rich EPROM, stock, 1993 1 Jim EPROM, stock, 1994 1 Yun EPROM, stock, 1995 1 Jim Exhaust Hangers w/ Bracket, new 1 Rich FX3 Actuator Clip 2 Yun Gasket, Header 1 Jim Gasket, Injector Housing 1 Jim Gear Shifter, OEM 1 Rich Gear, FX3 Shock 1 Yun Leather Shift Boot 1 Yun Lug Nuts NA Jim MAP Sensor 1 Yun O Rings, Fuel Injector NA Jim O2 Sensor (used) 1 Yun PCV Breather Hose 2 Yun PCV Hose - Factory "F" 1 Yun PCV Hose (under plenum) 1 Yun PCV Rubber Elbows 2 (L & R) Aurora40 Plenum gasket, White Racing products 1 set Aurora40 Plenum Gaskets 1 Jim Radio antenna motor and bracket (used) 1 Jim Screws, Interior Assortment NA Yun Seal, Transmission Rear 1 Jim Secondary Acuators (new) 2 Yun Spark Plugs (NGK TR55IX 7164) 1 set Jim Starter (new) 1 Scott(hizhrz) Switch, Seat/FX3 (used) 1 Yun Throttle Body Plate Screw 2 Yun Transmission fill or drain plug 1 Jim Washer, Rear Wheel Bearing Hub 1 Yun Water Pump 1 Scott (hizhrz) Wheels, Saw Blades, Fronts w/ Tires 1 set Aurora40 Wiper Blade Assemble, Factory Arrow 1 set Aurora40 Last edited by secondchance; 02-04-2011 at 07:52 AM. Reason: Add info |
10-05-2009 | #2 |
Re: WAZOO (?) Parts Inventory?
I think it is an outstanding idea!
I have the following parts in inventory/on-hand. I will make them available to any area ZR-1 owner that needs it quickly and agrees to replace/return the part. Serpentine belt C-Beam Plates Plenum Gaskets Injector Housing Header Gaskets Fuel Inkector O-rings (all years) Transmission rear seal Spark plugs (NGK TR55IX 7164) EPROM stock 1990 EPROM stock 1993 Eprom stock 1995 ECM 1995 Lug nuts Engine Full Power Key Module (1991-1995) Radio antenna motor and bracket (used) Brake master cylinder and resovoir (used) DIC 1992-1993 Transmission fill or drain plug Jim
10-05-2009 | #3 | |
I have plenty of time so I will order at dealer. |
10-05-2009 | #4 | |
I got three from Vintage Parts Inc http://www.vpartsinc.com/ Part number is: GM 10140538 Jim |
10-05-2009 | #5 |
Thanks. Jim.
I also have; 1 - leather shifter boot |
10-05-2009 | #6 |
Not to rain on any parades, but would it make more sense for someone to post up if they urgently need something, than to maintain a list of what is out there?
10-05-2009 | #7 |
I started an Exel spread sheet.
Those who need a copy, send me an e-mail address and I will forward. Any additional volunteered parts, I will add to the list. |
10-05-2009 | #8 | |
This list (the Wazoo Parts Inventory or WPI) doesn't stop anyone from asking about other parts or supplies they might need. One of the things that I discovered in the last week of 2 mantenance sessions was that if you get five or six ZR-1 owners together, there is an amazing amount of knowledge available. Several times someone would point out a problem they weren't able to solve on their Z, and someone else would offer a soultion, or at least something to try. Heck, just trading the extra interior screws I had for the ones I was missing was worth a lot. Jim |
10-05-2009 | #9 |
Like Jim said;
1. Incredible what can be done w/ access to a lift and wealth of tools Jim provided. 2. Incredible increase in "can do" attitude with 4-5 guys being able to discuss and contributing in ideas and labor. 3. Everybody has their own experiences and knowledge - together, sum adds to beyond most typical mechanics I have dealt with. 4. Above all, it actually was incredibly fun to work on a car rather than doing it despite misery (at times it can get miserable) because I had to, alone. |
10-05-2009 | #10 | |
5. Budweiser! 6. Wings David |
