Old 09-30-2009   #1
npritchard777
Default What causes catalytic converter damage?
I installed my Corsa system over the weekend and discovered that both my cats are bad. The passenger side cat actually had broken down and a big chunk fell out when the exhaust was cut off it. The driver side is nearly black but hadn't blown apart like the passenger. So I'm wondering what would be the most likely cause this much wear? The car has about 72k miles on it.
I've got a set of FIC injectors sitting in the garage waiting for me to get enough motivation to pull the plenum again. Could the stock injectors cause damage to the cats with bad flow rates?
-Nate
npritchard777 is offline   Reply With Quote
Old 09-30-2009   #2
gbrtng
gbrtng's Avatar
Default Re: What causes catalytic converter damage?
Running too rich OR too lean hurts them. And excessive oil usage kills their efficiency over time.
Old 09-30-2009   #3
As stated above but also impact due to speed bumps, potholes etc damage the honeycomb substrate until it starts breaking apart. Also 72K is about right. THe black may have been previous damage before the injectors were replaced.
If you need a factory replacement passenger side I have one low mileage one about 18K miles on it I picked up in the actic (complete) As you well know the cats and exhaust header are intergrated on the 90-91s.
Old 09-30-2009   #4
npritchard777
I actually haven't replaced the injectors yet. I've been dreading pulling the plenum (again) but I'll probably get to that this winter. I'll get back to you on the cat. The guy that did my Corsa was supposed to get back to me yesterday to let me know if/when replacement cats would be in.
With these integrated exhaust/cat, can the cat still be replaced without messing with the exhaust manifold?
-Nate
Old 09-30-2009   #5
No the 90-91 cats are one unit. So to deal with the cats your going to have to pull the exhaust manifolds on both sides. These are NLA from GM. GM made them seperate units in 92 and the rest of the model run. If he can find a factory replacement I would be very surprised
Old 09-30-2009   #6
npritchard777
Well that sucks. Maybe I should just hold off for a while and save some pennies for headers.
-Nate
Old 09-30-2009   #7
npritchard777
Oh, it wasn't factory replacement he was talking about. I think he said he found them from Magnaflow.
-Nate
Old 09-30-2009   #8
Yep I kinda figurered that as im running MFs on my car now but good luck getting it to pass emissions. Mine doesnt and CA is even more anal than AZ. Im running Jeal Long Tubes, With MF High FLow Cats and a Corsa system. With the original Cats I passed no problem.
Old 09-30-2009   #9
I Prolly will install SW headers and exhaust AND will be registering ZR1 in South Dakota There are NO vehicle emissions checks in good ole SD for licensing. I think I will run SW offroad headers without CATS
Old 09-30-2009   #10
Which is why my Z is registered in Flagstaff
