Old 09-22-2009   #1
Kb7tif
Default Headers Installed
Ya Baby. What a difference. A Must do mod for the LT-5.
My Set up is Watson 1 7/8" Small tubes Ceramic Coated, Random Tech cats (with shields) Straights back to Borlas . I was lucky and got a deal on the headers the cats/pipes were top notch done as it bolts right to ware the resonator should be Hangers and all. Much Louder. Resonance has been introduced into the system. I Like It.
Took her for a neighborhood drive under 1500-2000 rpms there is a definite increase in torque/power.
I dont know if these will pass smog so I just cut the pipes and used Butt Stainless connectors (nice) in my exhaust so I can replace my stock manifolds if needed. Need to really get a camera to show.
Install was really not bad at all Put in fresh O2 sensors, Made my own extension weather pack deal, (nappa) Dip stick lined up perfect, no new grommet needed. I wrapped all Wires and hoses (clutch line) with Thermo tech wrap, (very similar to the wrap used for the motor mounts).
Next stop Mild porting. Here is a pic of the headers before cleaning/purchase.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 09-22-2009   #2
Aurora40
Aurora40's Avatar
Default Re: Headers Installed
Cool!
Bob Saveland
Former owner of #2517
Old 09-22-2009   #3
carter200
carter200's Avatar
Nice addition
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 09-23-2009   #4
DMark
DMark's Avatar
Hmmmmm...., Those Heat Shields make great sense.
Wonder if anybody knows where a set could be found. The cats on the end of my SW tend to warm up my floorboards.
[IMG]http://i16.tinypic.com/4ig0b3a.jpg[/IMG]
D. Mark
Gentleman Farmer, U.S. Army-Retired
LS3,LS6,LT1,LT5,L98,L82,L36,L79,L76
DMark is offline   Reply With Quote
Old 09-23-2009   #5
Jim Nolan
Talking Re: Headers Installed
What cats?
Old 09-23-2009   #6
Eric870
Eric870's Avatar
pics please
Eric870 is offline   Reply With Quote
Old 09-24-2009   #7
What year ZR1 and where did you pick up the headers
Old 09-30-2009   #8
Kb7tif
The car is a 92. I bought the headers from a forum member, (they wouldn't pass visual Calif inspection).
When installing these i found in my exhaust system when they eliminated the Resonator, they cut off the resonator 2"pipes and welded right over them leaving a choke point. Well I cut this out.
Removing that choke point, installing new 02 sensors and the headers made a definite power increase really woke up the car, I wound it up to about 4K plus and started a sideways traction thing. Not wide open. Never did that before. Also noticed a slight miss now at idle.
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 09-30-2009   #9
Myself and Lgaff both have 92s with the same Watson's.
=Jeff= has the 2" version.
Old 09-30-2009   #10
And I have the exhaust sytem that came coupled to those Watson that Dom bought. Small tight community
