Old 09-10-2009   #1
scholtmj
scholtmj's Avatar
Default Aluminum Power Steering Pump
I read a post a while ago on Turn One having an aluminum power steering pump for LT5s. Turns out they do have one that is a direct replacement. Weighs 1.5 pounds less than stock and costs $250.
If you want to order one you can contact Jeff:
1-877-GOTURN1 OR 1-989-759-4206
Old 09-10-2009   #2
Default Re: Aluminum Power Steering Pump
cool! got a pic?
Old 09-10-2009   #3
scholtmj
scholtmj's Avatar
cool! got a pic?
Not yet....mulling over if 1.5lbs is worth $150 over a stock unit.
Old 09-10-2009   #4
fiber bar and a big dump would give you the same weight advantage, but much cheaper
Old 09-10-2009   #5
Very true Lee, however I was looking at the overall "form factor" of the unit and to see if its a viable replacement option for the community as a whole. The weight reduction was an added bonus. Small but some would agree early pound counts.
Old 09-10-2009   #6
RICKYRJ1
RICKYRJ1's Avatar
I could polish some more weight off them if you want
Old 09-10-2009   #7
Of this we have Zero doubt Ricky!
Old 09-11-2009   #8
batchman
Where this particular weight is located (high and forward) is a multiplier for corner-carving. I'd have done it if my rules would allow .
The aluminum should shed heat better too. Also important in my application. Still too much of a rule stretch.
- Jeff
[/I]
Old 09-11-2009   #9
Pete
Pete's Avatar
I'd buy it just in case i'm constipated.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
