08-31-2009 | #1 |
Left side Coolant fan issue
I was working on the windows on my Z this weekend. After a couple minutes the fan came on.. thing is the car has not been started for a couple days so I know the temp did not require it. Not sure what it could be but looking for some suggestions
08-31-2009 | #2 |
Re: Left side Coolant fan issue
Check for codes. If you went in to limp home mode the fans come on.
08-31-2009 | #3 | |
shut off engine then turn key to on, with engine not running fan stays off. I need to go through the troubleshoot guide in the manual which fan is the left? 1 or 2?
08-31-2009 | #4 |
Jeff, just one fan goes on or both?
If it goes on with with key on i'm thinking relay. Swap out relays. Check Prom. Pete
08-31-2009 | #5 |
Will do, and yes only one.
08-31-2009 | #6 |
If you ever want to come over and swap parts out of one of mine to test, let me know. Might save you some $
08-31-2009 | #7 |
Thanks Lee.. If it gets to that I will
need to troubleshoot it first
08-31-2009 | #8 |
09-01-2009 | #9 |
Not the Relay, Swapped and the same issue
I hooked up my Laptop, AC Request is set to 'Yes' even when the controller is 'OFF' Keep in mind I have C60 (Manual AC) So I followed the troubleshooting guide, and it says if I put a test light from Green connector pin #2 of the ECM to ground, I should get a light in Bi-level, AC, Max and Defrost.. it never lights. I need to check the wire and check the under dash connector, but the odd thing is the AC works.. so I am a bit confused on that.. I am guessing I have a loose connection or broken wire Ah well, I will check it when I start working on the passenger side window
