08-30-2009 | #1 |
Lateral Accelerometer
I am looking for the above part. It is part of the ABS system and is located behind the radio in the dash. Must be in good working order.
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
08-30-2009 | #2 | |
Re: Lateral Accelerometer / off subject
I have a set of watsons to be put in looks like late sept at this rate
1995 Convertible Supercharged Auto 1974 454 550hp (avatar car) On the blocks- -Scharger install ! 1992-Zr-1 Sold. Watson Headers Ported Plenum, Housings Random tech cats Fidanza Flywheel Chipped, Relocated Mat Woods 165 stat Borlas, Straights 1996 Lt4 Sold 1994 Lt1 Sold 2004 Z06 Sold AKA** Illenema |
08-30-2009 | #3 |
John PM member WEBURKE over at the other forum he has one for sale but I dont know if they a Z specific, I dont think so. GC
08-30-2009 | #4 |
John, remove your stereo head unit and it's mounted to the console with two screws. Put it in your hand. You should feel the pendulum swing back in forth on the inside. If it doesn't, whack it against your hand to free it.
08-30-2009 | #5 |
If that doesnt work, let me know. I have one.
08-30-2009 | #6 |
Thanks for the info Jeff. I will try that.
Just in case, 65ZR1, how much? Kb7tif, you here in Vegas? The heat has been a bit much. If you need help with the Watsons, give me a call.
08-30-2009 | #7 |
How does 20 plus shipping sound. Hopefully giving yours a whack works!
08-30-2009 | #8 |
Sent PM
10-10-2009 | #9 |
Is this unit "below" the radio? According to the SM it is below not behind the radio. I do not see why you need to remove the radio unit. I also am still looking for one of these.
10-11-2009 | #10 |
John, it does sit below the radio, but access to the area is tight.
