Old 08-17-2009   #1
phrogs
phrogs's Avatar
Default Lots ZR-1 and LT5 parts FS please buy it all!
Update I will be able to deliver up in carlisle so lets go people!
Ok before I hit the bay with these Ill give you guys a shot at them since it will probably be you buying them anyway! No need to line ebays pockets we already have to deal with paypal.
Bellhousings I have 2 of them $300 each
http://i150.photobucket.com/albums/s...s/IMG_1170.jpg
Throttle body good for a 63MM or larger had some damage by bubba needs finished machining done still stock bore. $250
http://i150.photobucket.com/albums/s...s/IMG_1163.jpg
http://i150.photobucket.com/albums/s...s/IMG_1161.jpg
http://i150.photobucket.com/albums/s...s/IMG_1162.jpg
The airfilter to throttle body accordian air duct $80
http://i150.photobucket.com/albums/s...s/IMG_1125.jpg
The ECM cover $75 SOLD
Tail light wiring harness $100
http://i150.photobucket.com/albums/s...ghtharness.jpg
A/C hard line from evaporator $125
http://i150.photobucket.com/albums/s...or14104967.jpg
Interior harness runs from dash to rear of car for lights hatch control among other things $ 100
http://i150.photobucket.com/albums/s...orharness2.jpg
FX3 and ABS harness one conector was damaged wiries good $50
http://i150.photobucket.com/albums/s...bsharness1.jpg
antenna cable from radio to antenna $35
http://i150.photobucket.com/albums/s...ttenacable.jpg
Seat wiring harness for power seats $35
http://i150.photobucket.com/albums/s...sportseats.jpg
Low tire pressure reciever $50 I have 2
http://i150.photobucket.com/albums/s...Sreciever2.jpg
low tire pressure sensors I have 2 left from this set green and orange $130 each
http://i150.photobucket.com/albums/s...arts/LTPWS.jpg
A/C line from accumulator $100
http://i150.photobucket.com/albums/s...or10157992.jpg
Engine harness pretty sure its from a 91 cut up and for parts only! SOLD
6 speed shifter console with door I have 3 of them they are not perfect they have scrathes and dings they are used. $75 each
http://i150.photobucket.com/albums/s...rconsole-2.jpg
Rear bumber support brackets I have 2 sets these are on the outboard corners of the LT5 bumper to hold up that ***! $100 a set
http://i150.photobucket.com/albums/s...s/IMG_1364.jpg
Front wheel well rear splash guards these are ZR-1 specific $75 each
http://i150.photobucket.com/albums/s...s/IMG_1368.jpg
Door panels black need the carpet replaced cat got to them $100 for the pair comes with new ACC carpet.
http://i150.photobucket.com/albums/s...s/IMG_1346.jpg
http://i150.photobucket.com/albums/s...s/IMG_1347.jpg
dash pad with black carpet $100 (I can get a better pic let me know)
http://i150.photobucket.com/albums/s...s/IMG_1344.jpg
number of springs valves and keepers I would have to count them all but Im sure some keepers are missing but 8 intake valves $200 for whats in the box
http://i150.photobucket.com/albums/s...s/IMG_1338.jpg
Exhaust hangers brand new! $ 75 for all three SOLD
Fuel delivery and return lines $250
http://i150.photobucket.com/albums/s...s/IMG_1443.jpg
O2 sensor extentions for use with headers $100 SOLD
ECM mount braket sits behind brake booster $100
http://i150.photobucket.com/albums/s...s/IMG_1451.jpg
rear storage compartment doors $35
http://i150.photobucket.com/albums/s...s/IMG_1456.jpg
headlights $100 each I have 4
http://i150.photobucket.com/albums/s...s/IMG_1435.jpg
headlight covers $40 each
http://i150.photobucket.com/albums/s...s/IMG_1428.jpg
http://i150.photobucket.com/albums/s...s/IMG_1429.jpg
ZR-1 rack and pinion less rag joint $150
http://i150.photobucket.com/albums/s...s/IMG_1459.jpg
Rear end suspension pieces, not including the spring brake rotors and the sway bar just the other parts $400
http://i150.photobucket.com/albums/s...e/DSC00163.jpg
rear toe/tie whatever bar I have 3 of them $100 each
http://i150.photobucket.com/albums/s...age/toerod.jpg
ZR-1 brakes probably need a rebuild been sitting for years $200
http://i150.photobucket.com/albums/s...s/IMG_1458.jpg
1991 airbag controler suppost to be good I really don't know? I have 2 if these $50
http://i150.photobucket.com/albums/s...s/IMG_1461.jpg
ACC carpet peices $65 for the door sills $45 for the others
http://i150.photobucket.com/albums/s...s/IMG_1463.jpg
http://i150.photobucket.com/albums/s...s/IMG_1465.jpg
Front frame bracket for wreck damage $55
http://i150.photobucket.com/albums/s...s/IMG_1343.jpg
Radiator upper and lower supports $75 for upper $65 for lower.
http://i150.photobucket.com/albums/s...s/IMG_1361.jpg
ZR-1 specific rocker panels $350
http://i150.photobucket.com/albums/s...9/IMG_1625.jpg
Pressure plate not sure if its for a L98 or a ZR-1 have to measure it but I think its the smaller one for a L98 $65
http://i150.photobucket.com/albums/s...9/IMG_1623.jpg
http://i150.photobucket.com/albums/s...9/IMG_1621.jpg
http://i150.photobucket.com/albums/s...9/IMG_1622.jpg
1990 ZR-1 Dash board plastic skeleton and wiring harnes airbag went off so I think the controler is no good and the CCM is seperate
$450
CCM has less than 20K miles on it $200
http://i150.photobucket.com/albums/s...9/IMG_1629.jpg
Power seat tracks I have 5 of them 2 of them are from a 88 so they have the extra spring all of them work I tested them in my car.
$100 each
http://i150.photobucket.com/albums/s...9/IMG_1631.jpg
Ill be back with pictures of the following later
Left and right timing chain tensioners 2 sets expanded $250 each pair.
camshaft sprockets viners and camshaft retainers $350 for all of it.
1991 LT5 engine requires assembly torn apart must be checked and rebuild comes with new crankshaft bearings, conecting rod bearings and head gaskets. Includes all accesories plenum and throttle body just not all in the photo will need injectors and harness $5000
JOHNNY P
Currently own
