Old 08-09-2009   #1
Default Our first LT5 pull = no problems
With Lee's help, starting at 8:15 this morning, we rookies managed to have my LT5 pulled in under 7 hours - not bad for first timers, methinks. Nuttin' to it, really. Having new LT headers made is a breeze getting the exhaust off, and the rest went very well.
As far as being able to detect anything with my #8, we couldn't see anything wrong. However, there was evidence of coolant seeping in at 3 cylinders; two adjacent to the water jacket hole at the IH/head junction. I understand Dom had some trouble with that as well. I was using Jerry's gaskets, but that alone does not seem to always be a given. I'm thinking some of that contact cement gasket adhesive around the water port might help. Suggestions?
Note the coolant at the gasket (looking down the IH to the head).
More pix later - more show and tell, but gotta run.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-09-2009   #2
Default Re: Our first LT5 pull = no problems
hotter than hell today....95 degrees. Had a good time, actually surprised at how easy it was...... the 7hrs included a run to the store for a Oil line wrench for Paul, which added an hour.
Tell you what when Paul says he is south of 80, he ain't shittin........his place is not even on the map.
Old 08-09-2009   #3
Great work Paul!!!!!
Look forward to the "updates" coming!!!
Cheers
Old 08-09-2009   #4
rhipsher
rhipsher's Avatar
Good job Paul. That's no small task for guys like us that don't do it every day.
Old 08-09-2009   #5
Default Credit where due
No telling how long it would have taken had Lee not been there - I owe him a big un now!. Having seen the video on the LT5 pull helped out in several ways - as well as tips from the gang here on the Registry as well.
P.
90 #1202
Sans secondaries
Old 08-09-2009   #6
Polo-1
Always helps to have a ZR-1 brother with you
Old 08-09-2009   #7
As you can see in the pics Paul only let me remove 1 ground wire and the wiper motor cover. The engine actually came out easier than an L98, we left the hood on with plently of clearance and no issues.
Its a big damn motor!
Old 08-10-2009   #8
Paul,
Very familiar sight! Doesn't look as bad as mine. My problem was primarily #4 primary runner and also #3 primary. Leak between IH/Head interface.
Switching from Flat Out gaskets and on Jerry's suggestion, I used his thin gaskets and I applied head shellac just in the area of the leak. Knock on wood, so far its holding fine.
Car would run fine but then I would come to a stop and motor would run rough. I would see wisps of white smoke even in warmer weather. This all started a week after installing the Mflows with the Xpipe. Prior to that, gasket had been fine for 5+months. Don't know if there is a correlation but it was curious.
Old 08-10-2009   #9
Jeffvette
Yep, I leave the hood on. But that car was being stripped. So off everything came.
Old 08-10-2009   #10
Aurora40
Aurora40's Avatar
Originally Posted by Polo-1 View Post
Are you using the cherry picker to hold the engine in place while you remove the car from around it?
Bob Saveland
Former owner of #2517
