Old 08-09-2009   #1
32valvZ
32valvZ's Avatar
Default Rear Spring Issues Pt 2
Ok, I replaced my rear spring with a 12,000 mile unit. I love the increase pressure from the 39.9 N/mm spring and poly bushings.
What I dont understand is why the car is still a 1/2" lower on the driver side. I set the original bolts with the castle nuts lined up with the cotter pin holes just like factory.
So what gives here. The replacement spring looks to be in excellent condition and was much firmer when installing than the original. I could even see the arc of the spring was greater than the one I took out.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 08-09-2009   #2
flyin ryan
flyin ryan's Avatar
Default Re: Rear Spring Issues Pt 2
Why don't you crank it up on the one side & drill a new hole for the cotter pin, just to see? Won't cost you anything to try . I know fibreglass springs are more of an art than a science, all springs actually to some degree.
Old 08-09-2009   #3
Kb7tif
Thats a nice choice for replacement. Does the firmness match the front well.
Im going to do the same. 1/2 " not a big deal, adjust a bolt.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 08-09-2009   #4
lbszr
lbszr's Avatar
I've got about 1/2 inch lower on dr side also but it handles really good with recent alignment (but just looked for any delamination because your posts are makeing me paranoid and getting ready to take it to track and would not like it to snap). A theory I've been thinking about for this winter, is a shop with scales on all four with torsion bars disconnected would show were the problem is. I'm cheap though soooo.......another theory is disconnect bars, jack front-in-center point and see if it leans, and then jack rear and check same because I think the front spring is the problem on mine. Torsion bars might need adjusted also.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 08-09-2009   #5
32valvZ
32valvZ's Avatar
I'm gonna play with it some today and see if I can get it leveled out. I have some waxed locking nuts, so I wont need to drill another hole.
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 08-09-2009   #6
32valvZ
32valvZ's Avatar
The car seems to handle nicely. On the highway when at speed, where the road dipped, my B&B was kissing the asphalt and throwing sparks I'm not sure why the original 49k mile spring was so soft........
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
