Old 07-25-2009   #1
32valvZ
32valvZ's Avatar
Default Rear Spring issue
I noticed my car was sitting lower on the driver side. I wanted to lower it down some anyway, so I bought the longer bolts and did so. I couldnt get it even in the back with the new bolts. I had to use a new one and a stock one in conjunction. It looks good and even, but now it scrapes the resonator on dips while cruising.
Is my spring worn out too far? Is that why I couldnt use both long bolts?
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 07-25-2009   #2
ZR1Vette
ZR1Vette's Avatar
Default Re: Rear Spring issue
There are reports of 'spring' failure due to delamination (not like a layer cake but rather the bonding)/ cracking of the synthetic springs due to age. First starts as you are describing your situation then gets progressively worse (basically spring failure).
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 07-25-2009   #3
rhipsher
rhipsher's Avatar
Mine did the same thing a while ago. And the funny thing is when you put the new spring and the old side by side they look identical and there's no signs of damege. It simply looses its regitity.
Old 07-26-2009   #4
32valvZ
32valvZ's Avatar
So, its pretty well done I guess. I am planning on looking for a low mile used one. Does it absolutely have to be for a ZR-1 or can I use one from say a 96 coupe?
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 07-26-2009   #5
89-96 are all the same , but remember there are different spring rates..
Old 07-27-2009   #6
Kb7tif
http://www.idavette.net/hib/c4/sustunch.pdf
Here is a chart One can see the huge difference of the z51
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 07-27-2009   #7
Kb7tif
Your spring sounds shot, and when those lowering bolts are used they soften up the spring. I have mine lowered with the bolts its a too soft for my liking, I will change spring rate or get the adjustable spring,,,
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 07-27-2009   #8
HIZNHRZ
rhipsher,
Are you saying that the back of your car (from driver side to passenger side) did not sit level so you replaced the rear leaf spring. After you installed the new leaf spring, did it then sit level?
Old 07-27-2009   #9
32valvZ
32valvZ's Avatar
Thank you. Thats great info!!
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 07-28-2009   #10
32valvZ
32valvZ's Avatar
So I found a spring from a 96 CE vert with 12000 miles on it. The rate shows 39.9 N/mm My Z has one thats showing 33.0 N/mm Will this work ok with the FX3?
TIA
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
