Old 07-24-2009   #1
secondchance
Default Rear tie rod
When I removed the rear wheels for cleaning I noticed tie rod end rubber boot looked squished and ripped. So, I bought a pair of polyurethane boots. Then I read somewhere that the tie rod end have a plastic swivel joint in them.
My question is, do these joints wear out? After 105,000 miles, should I consider replacing the joint rather than just the boot?
Old 07-24-2009   #2
Scrrem
Scrrem's Avatar
Default Re: Rear tie rod
I do believe that there is a wearable joint at the knucke and also where it attaches to the batwing. At 105,000, it may be time to replace that. I am contemplating replacing this whole assembly on my 90 when I upgrade to Polyurethane bushings. Some more experienced member may want to step in here.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-24-2009   #3
I would expect worn rear toe rod component to exhibit the same characteristics as the front counterpart. With the tire off the ground & suspension compressed, if you can detect wheel movement in the horizontal axis, then it is time for replacement.
Old 07-25-2009   #4
secondchance
Thanks guys. It makes perfect sense - jack up the car and see if I can wiggle the tire.
Old 07-25-2009   #5
Don't forget to compress the suspension at the wheel you are Testing.....if I understand Jerry correctly...which I may not!
Old 07-25-2009   #6
You do Tom.....
