Old 07-23-2009   #1
Kb7tif
Default This fall
Watson Headers/ Straights to the borlas
Ported Plenum/ IH
New Matched Injectors.
Already Have the headers/injectors.
I know the fidanaza made a nice difference, hope this does nice as well
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 07-23-2009   #2
Default Re: This fall
You'll like it!!
Old 07-23-2009   #3
Ported Plenum/ IH
Tuning is a critical element to making the package work.
I have a very similar setup including the Watson's.
Old 07-23-2009   #4
blackjack
i have a similar setup,except for ssw headers....i loooove it...no resonance
...next winter,its van deventer heads,and underdrive pulleys
bj
Old 07-24-2009   #5
bj
BJ,
Just put on the UD pulleys and I have a set of VD heads in the garage. Based on my anecdotal evidence from 1/4 mile runs using the same track, the UD pulleys are worth about .7mph.
Old 07-24-2009   #6
BJ,
Dom, did you do your data logging from a rolling start? Otherwise, the ambiguity stemming from all the variable/interacting factors surrounding a consistent launch would obscure .7 mph, no?
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-24-2009   #7
P.
Paul,
I did use the word "anecdotal" for that reason. I don't consider it scientific evidence however, it does provide a data point. I drive at Byron pretty consistently and .7mph is outside the typical variance I would expect with my driving. The UDs were the only change made since the last time at the track. Weather conditions were similar and somewhat warmer than last May when
I ran the 116.1. With an additional change to the calibration, the mph went up further. I look at trap speed because of the fact that it is less susceptible to variation from factors such as launch. In this instance, my launch in the previous run was better.
