Old 07-03-2009   #1
USAFPILOT
USAFPILOT's Avatar
Default Brakes
My brakes seem to be slightly engaged after a while driving.
At first the pedal is spongy...then after some driving it gets real firm and works quite well...but if I put the car in neutral to coast it feels like it is slowing down on the brakes a little...and once I park it in the garage it wont roll. But it will roll again once it has cooled off.
This is not due to the e-brake not being disengaged. That is the first thing I checked.
I dont want these rotors to warp up...is this normal?
Old 07-03-2009   #2
Default Re: Brakes
My guess is either the brakes are semi-engaged like you suspect
or you may have wheel bearing on the way out
try the wobble the wheel test while on a stand and see if you have excess play
plus let's see what others think -- even though the wobble test is easy.
Old 07-04-2009   #3
Default Re: Brakes
Hi, I don't know if this will help as my 90 maybe different from the later cars but in the FSM Brake section there is a diagnostic outlined in the Brake Troubleshooting chart for "dragging brakes". The answer for adjusting the Brake Pedal was the closest match to my symptoms, so I used that soloution as a starting point.
In my 90 it's so simple that I thought it was a miss-print. It said make sure the brake pedal is at the proper height by pulling up on the pedal. I did this and heard some clicks and the pedal moved! When the clicks stopped, the movement stopped. I was dumb founded, but when I tested the car the rear brake dragging was gone!
The only other answer in the chart involved the booster rod. On a 90 the rod tip has to be level with the outside face of the booster ( where the M/C bolts up ). If the push rod is too far out the booster applies enough pressure to the M/C to drag the brakes The push rod adjusts by turning it like a screw.
The only other thing I can remember is that there is an adjustment procedure for the parking brake....but I don't remember it...sorry...
Old 07-04-2009   #4
LT5-Lee
Default Re: Brakes
I would suggest flushing the fluid. I had this happen one time on another car where it got so bad I had to relieve pressure just to get home. It seems a particle of trash or rust clogged the return port on the MC. I have also seen brake hoses fail and allow fluid to pass from the inner core to the outer rubber shroud and basically pinch off flow.
An Unarmed Citizen is a Future Peasant.
Something BLOWbama & Hilary are trying to accomplish now at the UN with the "Global Small Arms Treaty"
LT5-Lee is offline   Reply With Quote
Old 08-24-2010   #5
USAFPILOT
USAFPILOT's Avatar
Default Re: Brakes
Flushing the fluid fixed it...now I am going to replace the pads and install some freshened up rotors and flush again for good measure. I also did a complete flush using DOT4. Ive always heard you can use DOT4 in a DOT3 system but not DOT3 in a DOT4.
I'll be using Hawk HPS pads and some slotted rotors from a previous vette. I wish I knew who made them but I know they are practically brand new and from Canada.
Should I use any additive on the pads before I install them? Ive seen that done before but I don't think it is necessary.
Old 08-24-2010   #6
Default Re: Brakes
Looks like Dot 4 is a good upgrade.
>>> http://en.wikipedia.org/wiki/DOT_4
I am about to do mine so I will do the same unless there is a reason not to.
"DOT3 has been all but replaced with the superior DOT4 as there is little cost difference between the two."
From >>> http://en.wikipedia.org/wiki/DOT_3
Dot 5.1 looks like the real winner even out performing Dot 5
See >> http://en.wikipedia.org/wiki/DOT_5.1
Wonder if there is any reason not to use 5.1 in our ZR-1's ???
Old 08-25-2010   #7
Kb7tif
Default Re: Brakes
I think the fluid flush is a temp. fix and the master cylinder's rubber is breaking down and master needs to be replaced. mine did this.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 08-25-2010   #8
USAFPILOT
USAFPILOT's Avatar
Default Re: Brakes
well that should be fun...shiza
Old 08-25-2010   #9
pantera1683
Default Re: Brakes
It's not very hard to do.
pantera1683 is offline   Reply With Quote
Old 08-25-2010   #10
Default Re: Brakes
Where is a good place to get a rebuild kit for the MC on the ZR-1
Tom Henry Chevy? or any dealer? Are they available easy?
I think mine needs it since I too have the low pedal - spongy syndrome now.
Prob the orig Brake fluid in my system 63K miles now.
